Page 561 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
GTracing
478
1,114
Such is the magnitude of RDOA3 failure, yes.
Afaik, Prior to this leak, RDNA3 being broken was only rumors and speculation. This is the first real confirmation.
Even if you fully believed the "RDNA3 is bugged rumors" (which I was skeptical of). It's still wild to see just how much missed potential there is. The performance delta is bigger than the bugged GTX 480 and the fixed GTX 580.
Goop_reformed
316
341
Goop_reformed
316
341
I heard AMD missed the target by at least 30%, and all that hard work into saving die space really screwed them over.
adroc_thurston
8,571
11,303
So. What is Jim Keller doing these days....
Being a CEO of Tenstorrent.
So at 5.5Ghz the INT score would be ~ 3800, assuming the clock was correctly reported. That can't be right.
It's not quite that linear of a scaling, but yes.
In fact, the leak above comes from GPD itself, they are comparing the AI 370 to the Phoenix 8840 as a direct drop-in replacement in their GPD Duo, same TDP options.
It's the same FP8 socket so yes, all it takes is an AGESA update, fresh solder balls and there you go.
Glo.
5,930
4,991
I would like to point out one thing.
If the scores for Strix Point arer correct, and there is zero reason for them to be fake, or mistaken, then we are very close to 2060 mobile performance, and Zen 6 APUs might actually be within the range of that performance.
2060 is 6000 pts in 3D Mark TS. With 24 CUs/12 WGPs, and any form of SLC/Infinity cache - we might get it in an APU.
inquiss
634
897
I think we should set our sights quite a bit higher for HT hao SKU
Abwx
12,025
4,988
So 12 and 10C only for Strix Point, no 8C cut down version :
Reactions: Mopetar
poke01
4,872
6,202
Does Strix point ship with Pluton?
Edit: they do… more ms mandated bs
