Page 539 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
fastandfurious6
984
1,092
hype train is back!!!!!!!!!!!!!!! 🚆🚂🚃🚄🚅🚉
underpromise, overdeliver
what's the best way to secure the earliest top spec laptop available? zephyrus g16 on Asus USA I guess
Fjodor2001
4,635
748
yuri69
699
1,252
If 16% is accurate for 1T workloads as well then AMD have gained less than Intel from the same kind of changes. That would not be great, especially with ARM based architectures showing good gains.
I've posted that in the past but AMD got a long history of flopped "major architectures".
The argument about the current AMD being "different" doesn't hold since RDNA3 was mismanaged badly.
Reactions: Tlh97 and del42sa
Fjodor2001
4,635
748
+14% headroom in clock speed (5Ghz+ versus 5.7Ghz on launch)
~8% IPC (early reveal) vs 13% on launch.
>15% ST uplift turned out to be ~29% ST uplift.
Quite some differences. I wonder what the purpose of the intentional sandbagging is.
Jun 4, 2024
Reactions: sirmo
Fjodor2001
4,635
748
CouncilorIrissa
788
2,855
AMD laptop CPU roadmap with Zen5 X3D + more:
(Link above also has roadmap for Intel mobile and Nvidia.)
Wccftech:ified corresponding article:
I wonder what's the lowest you'll be able to get an STX Halo laptop for. $2000+ laptops?
adroc_thurston
8,610
11,325
StefanR5R
6,851
11,029
We now have 9950X announced, and a month out from launch.
Model number, core count, base and peak clocks, TDP, cache sizes, supported memory speeds, and the month of launch were disclosed. Together with fuzzed performance data.
Launch date, MSRP, SPEC performance, PPT limit, and more details however are still top secret.
And they are even more secretive about server parts. Whose core microarchitecture is being reused in client parts.
Joe NYC
4,234
5,837
SMT scaling being lower would imply that they've removed some bottlenecks that previously stalled the hardware thread or otherwise left it unable to utilize the core to a greater extent.
That would be a very favorable scenario (more 1T performance, less SMT) if true
The slides AMD shared had a lot of MT workloads in the 16% claim but the gaming slides are already indicating a larger gain than that IPC figure. They put Zen5 a tiny bit ahead of the Zen4 X3D which indicates a ~25% performance uplift in gaming.
Immediately something does not mesh so with that in mind I am waiting for Anandtech to do the SPECint 2017 1T tests to work out the IPC uplift in that benchmark. If it is less than 32% then adroc/Kepler were unambiguously wrong, if it matches or exceeds they were correct.
Given the gaming uplifts it suggests the 1T IPC uplift is greater than nT which is something that adroc has said.
Also, AMD sandbagged hard with Zen4. Pre reviews it was looking like it would be a lot slower than Z poen3X3D in gaming but it was actually on par and is now frequently ahead by a small margin.
So a long way of saying wait for benchmarks if you want definitive answers. In the interim just have fun, there is no need to lash out at people, it is just a tech thread, it is not that serious.
It will be interesting to see if that Infinity fabric clock of 2400 MHz applies to desktop chips or only laptop.
If Zen 5 desktop supports it, and if memory support goes up to 8,000, then DDR5 7200 speeds should be easily achievable with nice integer multipliers.
In the reviews, AMD used old mobos and DDR5-6000
inf64
3,884
4,692
Also no direct comparison with 7000 series models, no ST uplift, no performance/watt numbers (which should be massively in favor of Zen 5).
adroc_thurston
8,610
11,325
MacBook Pro pricing at the lowest then, I guess (so $1600+).
They can go lower, the pitch is replacing APU +dGP combo with something sleeker and cheaper.
Basically entirely depends on design win volume. If it's high enough, it'll be reasonable money to push the swimlane thru. If it's not? Well too bad, 2kilobuck starter price.
Joe NYC
4,234
5,837
It seems that a lot of Strix Point laptops are coming with NVidia dGPU. So since Strix Halo is dropping the dGPU, the increment is going to be less, since the OEMs will be dropping the NVidia dGPU.
Maybe ~ Strix Point + 4060 price?
