Page 534 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
ToTTenTranz
960
1,577
Sort of. 3.5 actually works.
It supposedly has better voltage-clock curves, which is why they're putting an additional 2 WGPs in there without increasing power consumption, but IPC-per-WGP should be similar between the two.
Of course, Strix Point's GPU should be even more bandwidth bottlenecked than Phoenix's because there's 33% more WGPs and 13.8% higher RAM bandwidth (plus a CPU with more cores = more demanding for the memory controller).
adroc_thurston
8,614
11,327
Yeah, but clocks is where RDNA3 struggled.
Phoenix wasn't bandwidth-bound much, and neither was RMB.
STX is, though, MALL would've been real handy for actual video games
Reactions: Joe NYC
fastandfurious6
984
1,092
CPU: AMD Ryzen AI 9 HX 170
Min/Max/Avg: 3545/3673/3653 MHz
Codename: Strix Point
Single: 2544
Multi: 14158
https://browser.geekbench.com/v6/cpu/6418984
This is extremely disappointing
my GB 6.3 results on 7840HS (same as 8845HS)
single 2396
multi 12477
and that's with 3 browsers open, 50 tabs active and another 600 inactive, several apps open and music playing in background
YIKES!!!!!!!!!!!!!!!!
Reactions: invisible_city
gdansk
4,793
8,085
The 7840U I tested scored 2642/11352 in GB6.
But the model name, clock rates and/or clock rate reporting don't seem to be correct for that Strix example.
fastandfurious6
984
1,092
are you saying the strix point GB bench is fake?
also the theory that "linear 5.1 will be 3500+" is plain wrong
just did 7840hs gb6.3 @ base freq with boost disabled
1975 single
10848 multi
~20% difference
which means at very best case strix point at max boost (?) has around 2800 single 15000 multi
fastandfurious6
984
1,092
if fire range (mobile 9950x) manages ~3500 single GB6 at acceptable temps then that's a success
but probably gonna be around 3000
let's see
Abwx
12,034
4,995
single 2396
multi 12477
With browsers opened those numbers are meaningless, the higher score at NBC is 2721 for the 7840HS, wich is 13.5% higher than your score, so your CPU didnt clock at 5.1GHz in ST, rather at 4.6-4.7GHz.
Hitman928
6,755
12,500
Zen5 @ 5.7ghz = ~3950points according to that scaling
Almost seem too good to be true 👍
GB doesn't scale linearly with clock speed across a wide frequency range, but it usually isn't too far off. It can be accurately approximated as linear if the frequency difference is relatively small, but with multiple GHz, it's going to be less than linear.
Reactions: lightmanek
Hitman928
6,755
12,500
1975 single
10848 multi
~20% difference
GB says your higher run was run at between 4.6 - 4.7 GHz. So from base, that is approximately a 22% increase in frequency for 21% more performance, pretty close to linear.
Edit: Comparing your base freq. run to the STX point result, the STX CPU has a 29% higher score while running at a ~4% slower frequency. Not sure why you think that is extremely disappointing. If it ran at 5.1 GHz, it should score at least 3350 pts, if not higher (3554 would be perfect scaling but it won't quite get that).
adroc_thurston
8,614
11,327
Bingo.
Now, if you look at the subtests, that's where it gets more interesting.
The INT side is pumping the score.
inf64
3,884
4,692
I was about to reply to that post but you beat me to it again. The scores are looking good so far, but we need to wait for granite ridge leaks to be sure.
H433x0n
1,224
1,606
Trolling is not permitted. Please read and adhere to the forum rules.
So it’s official AT canon that Strix does 3300+ GB6? So we’re going to have the hype train derail twice?
Reactions: Henry swagger
Jun 4, 2024
Well nothing is certain at this point. Same goes for Lion cove copium/hopium that it can get noticeably faster in Arrow Lake ;)
Intel said it could. It’s not hopium except to hope Intel stopped redacted.
esquared
Anandtech Forum Director
