Page 531 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Jun 4, 2024
Same here. AMD should introduce 9970x with 1 CCD Z5 X3D and 1 CCD with Z5c. However for some reason there seems to be so much resistance for increasing core count in this forum. For me 4 generations of 16 cores is not a smart decision by AMD.
Yeah. It’s just fanobyism. Same thing happened with Intel, people for years said 4 cores is all you need. Then Zen came out and suddenly 8, 12, 16 cores became desired.
After 16 and Zen 2, the only higher core parts are thousands of dollars, nevermind more expensive mobos.
Same thing for higher bandwidth. We’ve been stuck on dual channel forever.
AMD, it turns out, likes to make money just as much as Intel and Nvidia.
yuri69
699
1,252
adroc_thurston
8,609
11,325
DisEnchantment
1,779
6,798
Almost within reach of Phoenix scores within 3.6G!!
Zen5 @ 5.7ghz = ~3950points according to that scaling
Almost seem too good to be true 👍
2950--> 4000+ @ 5.75G on DT parts
This is +35% perf.
Fingers crossed, on DT with a bit more cache it would be glorious.
On Linux it will be comfortably cruising at 4200+ Points
EDIT:
If the reported frequencies are correct.
DisEnchantment
1,779
6,798
Nothingness
3,374
2,475
Can you point to the particular SPECint benchmark, what compiler will do it, and how much it improves the score? Now SPEC*fp* I can believe, especially the Fortran code, but I could care less how well a compiler will handle Fortran code, or really floating point code in general. That's much less relevant to latency dominated / interactive type performance that forms most people's impression of whether "this PC is slow" or not.
x264 can benefit from auto vectorization. See this for instance. I had also found some article that showed benefits on SPEC 2k gzip, but I can't find it any more.
But yes I agree, it's marginal for integer workloads. My point was more about extra instructions being added that could be useful for various workloads. For instance Arm only introduced integer min/max/abs, bitcnt in Armv8.9 as an optional extension. This could have a small but measurable impact on some workloads (not thinking about SPEC in particular); here is what gcc does: https://godbolt.org/z/45sPdfhKW (I have made it simple; both gcc and clang can recognize more complex code sequences for bit counting).
But this is once again the reason I primarily pay attention to gcc/llvm/clang subtests in SPECint and Geekbench rather than the overall score. You aren't going to speed that subtest up with SIMD to any degree, not even if you could hand code it. And to those who object "how often do you compile stuff" that's not the point. The type of work those compilers perform is a fairly good representation of code you see in a lot of modern computing, from handling the GUI, to processing XML/HTML/CSS/etc. in a browser, to other programming/scripting languages like Javascript/Perl/PHP. If you want to know how well a CPU does processing PHP then run a PHP benchmark. If you want to know about its all around integer performance, not dominated by any one factor, not relying on SIMD and other extensions, and not overly influenced by either very large caches or high frequencies, the gcc/llvm/clang subtest is what you want.
People can feel free to disagree, but take they should take their argument to Linus Torvalds. He holds the same position, and would provide a much better defense of it than I. If they can convince him, I'll be convinced too. I've seen people try, and he's demolished them in hilarious fashion every time.
And I certainly won't disagree :)
branch_suggestion
905
1,966
Remember, a real launch has pricing and exact availability.
This was a preliminary launch, nothing was final.
Same with Intel, both were playing games in their presentations.
So with that all said, are we back?
tsamolotoff
261
512
What is up with AMD using considerably lower base clock speeds and TDP's?
Here's a third theory for ya - the thermal density is so high, and AMD hasn't bothered with sanding the dies again (in addition to placing and gluing "structural silicon" on top of all dies), so a chiplet can't handle even 65W now at reasonable voltages and clocks.
H433x0n
1,224
1,606
Who wants to make a bet this is the actual performance of Strix? I’ll be the party pooper and bet this is within the margin of error for final performance.
H433x0n
1,224
1,606
Yessir most definitely Zen5%.
Well, it's technically +6.5% if you go by the average 7840HS score which is 2389. It's also geekbench, there's a ton of variability and this could be a low scoring sample. Using the napkin math of HXL, 3400 / 2389 nets +42.3% GB6 1T score over a 7840HS. It'd also mean an improvement of 69.5% in nT performance.
All of this from a core that AMD claims is a +16% IPC increase running at the same clocks.
H433x0n
1,224
1,606
8955HS scores like 2750-ish in GB6 1t at so that's 23% bump in perf.
No it doesn’t. The average for a 8945HS is 2380. I doubt there’s a mythical Hawk SKU that nets that much more 1T performance.
By AMD’s own slides it claims to be a mere +5% better than SDXE in GB6 1T. This is it, this is Strix performance. I’m sure there’s going to be better configured laptops that get better scores, who knows this could be on the really low end.
adroc_thurston
8,609
11,325
Please for the love of God, stop using GB averages, they accumulate results that use silly power/performance profiles.
Use search instead and average all the sensible 8945HS results.
Or 7840HS if you like that one.
Hamoa published 1t GB6 was like 3k+ so yea? Not far off.
poke01
4,881
6,222
Nice, it’s similar to M2 from 2 years ago at the same clocks. So much for AMD being so great that everyone will be catching up for the next couple of years. 😝
