Page 440 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
Abwx
12,028
4,990
Wouldn't be the first time GB reported the wrong cache size. On the other hand, it could be correct and a Zen 5 update to their embedded platform.
All other cache sizes seems to be right, so it s unlikely that GB made a miss just for the L1D, and the ST score, if at about 1.4GHz, is aligned with the late april GB submissions, this would translate as about 23% better ST score than a 7950X.
Goop_reformed
316
341
23% is bad
RnR_au
2,910
6,502
Memory capacity is king. Strix Halo + 64GB RAM will beat a 4090 in any AI task if you scale it up sufficiently. And for local LLMs where capacity is by far the biggest bottleneck, it won't even be close.
Strix Halo directly competes for the semi-pro market that is buying 4090s instead of RTX 6000s. Significantly slower for tasks that fit inside 24GB, but can be used for tasks a 4090 can't touch.
Just on this, I noticed this thread this morning;
From my understanding, Strix Point will also feature a souped up NPU, so Windows folks might get some inferencing love if any of the partners will field Strix Point laptops with 128GB of ram.
Reactions: Tlh97 and Mopetar
Abwx
12,028
4,990
poke01
4,873
6,205
Great points. I would also say the huge bandwidth helps as well. That’s before Apple is using LP5X.
MLX is also advancing as well. Honestly, the more companies try to break down Nvidias iron wall the better.
I would like to say AMD should make a larger APU with more bandwidth. Maybe, Zen6?
Looking at OpenAI’s event yesterday, the hype around AI is not dying. Lots of memory is needed.
branch_suggestion
897
1,955
Eng samples having unoptimised firmware or straight up firmware locks makes any performance assumptions dubious.
That one Weibo post that sent people mad is a very obvious example of limited testing. If they are a Lenovo product manager then it makes it far more likely that AMD would put in firmware locks to make such lapses of judgement moot.
H433x0n
1,224
1,606
There s forcibly some big variability, in a comparision with a linux driven 7800X3D, wich is sure to be at 5Ghz, that could be 27-29% or so, at this point the GB submission give no clue about the test plateform, given that it display 6.74GB RAM it could be single channel, or not.
For the April GB scores when compared against a 14900K w/ DDR5-4800 JEDEC it ended up being 20-22%. If that were the score I think that'd actually be quite good since a desktop chip with larger L3$ would score even better than this. If you extrapolate the small IPC bump from a desktop chip having fatter L3$ and the slight fmax increase over Zen 4 you would see ~30% 1T perf increase.
I personally don't think it's worth drawing conclusions from it though since there's so much variability in GB scores. When searching through scores, you can see the same processors get results that vary by 10% from user submitted data. About the only thing that seems constant is that the Zen 5 core doesn't do great with the AES subtests.
moinmoin
5,248
8,463
Will be highly interesting to see how this works out and what strategy for switching the threads over they might employ.
Will they switch on a thread level, on a core level (thread pairs), what thresholds, etc. ...
If the previously discussed patent 10698472 is any indication it would work on an opcode level, only implementing opcodes that can be churned through without any real computation (like JMP or anything keeping I/O going etc.) otherwise throwing an illegal opcode exception to move the computation onto a fat core.
The real question is just how castrated Z5LP really is.
Going by above patent it could well be so castrated it couldn't be used as a full core of its own. It would be little more than a fast shortcut for the simplest of all opcodes.
Mahboi
1,058
1,969
I don't know, how would that work for a LP island?
Sounds like something that would fire up the fat cores for literally any workload.
cherullo
59
133
Yeah, the LP cores do need to perform proper computations to actually prevent the HP cores from powering up.
Since it's transparent to the OS, it can support any mix of instructions, regardless of extension. For example, it would be nice to have memory and string instructions from AVX512, even at reduced throughput, but no FMA at all. You can even support certain zeroing idioms without supporting the instruction itself.
You can also strip out all the legacy stuff like 16- and 32-bit modes, x87 FPU, etc. It can be really, really lean.
What moinmoin described is more like a DMA engine, which is also useful.
SteinFG
743
873
How possible it is for AMD to just ditch numbered tiers? Instead of ryzen 5,7,9 it's just all "Ryzen AI" for Kraken chips, and maybe "Ryzen AI HX" for Strix chips?
LightningZ71
2,696
3,395
Could the LP cores just be stripped of all the "go fast" bits and anything else that can't be emulated in microcode and essentially be maximally efficient microcode engines instead? They could retain full isa compatibility with the performance cores.
Mahboi
1,058
1,969
Weird hypothesis, but frankly Intel and AMD always used the numbers very poorly.
bad idea
SteinFG
743
873
Out of 9 numbers, 4 are used: 3/5/7/9. It's a generally poor system because you don't want to have many tiers(muddies the lineup), and you don't want to have lower numbers than 5. Anyone identifies i3/R3 as "bad", to the point that some noobs actually think a 2023 i3 is worse than a 2014 i7.
Frankly I think clothes did it pretty well: S/M/L/XL?
Make 4 tiers:
- Light
- Medium
- Heavy
- Ultra
But it's kind of problematic too since it's a two sided coin, you get Bigger Number Better just like you get Lower Number Worse.
This just replaces a number with a word, same meaning. What actually should've happened is, each gen should shift the window of numbers. Example: Zen 1 would have Ryzen 1,2,3 tiers, Zen 2 will have Ryzen 2,3,4,5 tiers. Zen 3 would have Ryzen 3,4,5,6 tiers. Zen 4 would have Ryzen 5,6,7 tiers. This way, you avoid the problem you are talking about. Someone will say "I have a Ryzen 4", and you instantly know it's a chip made inbetween 2019 and 2022.
Mahboi
1,058
1,969
Yes, that's the point.
You just create a huge new slew of problems.
So just the difference between a 3950x and a 7600.
Just a smidge of 31% better MT perf on one, vs 30% better ST perf on the other.
No, I don't think that's better.
SteinFG
743
873
Is it a lot better when Ryzen 7 has 200% ST and MT better performance than Ryzen 7? (1700X vs 7700X), I don't think that. With intel it's even bigger
Mahboi
1,058
1,969
Mmmh, good point. Maybe it'd just be better to remove it entirely and just leave the Gen/Tier/Rev. And you can bin the "AI" bit too.
