Page 430 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
rainy
523
453
You're trying to boil down CPU performance factors to a single metric.
That's really-really not how it works!
You must understand, that despite of his nickname, he's devoted Intel user with a rather strange fetish for numbers.
Fan, fanboy, stan, etc. are allowed in the tech forums as they are used derogatorily far more often than not.
Thanks for your understanding and cooperation
Mod DAPUNISHER
  • Love
Reactions: spursindonesia
AMDK11
496
441
This is one of many factors and I am not saying it is the most important one.
This is the only way to find out and compare with Zen because LionCove separates the FPU ports from the ALU ports.
Reactions: Penguin005
adroc_thurston
8,597
11,325
It's not really one relevant to Zen5 at all.
You can just find the C&C article where Clam profiled 7950X in vidya to see the key back-end issues.
You. Just don't.
adroc_thurston
8,597
11,325
These are just two examples of online gaming among many applications and loads.
Most client workloads are like gaming: horribly front-end bound, and when they're not, throw ROB slots at it.
Like, this is why MTL is an IPC regression in client w/l's. Same core, same boundaries, worse memory setup!
Smarter people already did the profiling for you. All you gotta do is read the charts. Not that hard.
AMDK11
496
441
So you're saying that AMD added 2 ALUs to Zen 5 for no reason, because 4 ALUs in Zen4 is not a limitation?
AMDK11
496
441
well there gotta be some.
Not the main one, no.
Consult the chart.
AMD must consider the entire spectrum of workloads, not just games. Zen5 is designed not only for consumer computers, but also for Epyc.
Are there examples of profiling for other workloads/applications?
adroc_thurston
8,597
11,325
Thank you for stating the obvious and not reading what I've said before.
It's designed for client and cloud (and so is Zen6), these kinda share workload footprints, a lot being membound JITs and all.
Pay me and I'll do it.
  • Love
Jayzen
35
89
51
I still see very little reason to believe a 30-40% IPC uplift from either side (let alone more) is at all realistic in 2024.
To clear the air about my supposed partisan allegiance: I think Arrow Lake's going to be quite disappointing as well, and already called out Royal Core as essentially being Bulldozer with more money thrown at it.
Joe NYC
4,228
5,834
Just for context , Zen 4 was ~10-12% uplift with some minor tweaks versus Zen 3. If Zen 5 ends up being just 10-15% faster at iso clocks versus Zen 4*, then something went wrong in the design process. AMD has such advanced internal performance modeling tools that I find it impossible they would waste so much time and money to get so little out of it.
Don't forget the leak from High Yield guy: :tearsofjoy:
Mopetar
8,531
7,795
Well, a 5-10% IPC gain with clock regression is not at all surprising if I'll be honest. Just making the core wider and increasing total throughput, which appears to be what AMD has done, is actually a hilariously inefficient way to increase IPC on x86 due to register dependencies and memory/cache bottlenecks.
This is just wrong on so many levels. Both AMD and Intel CPUs have a massive register file and use register renaming to eliminate false dependencies. Adding more execution ports doesn't necessitate clock regression either.
I'm curious how you expect to improve IPC without being able to execute more instructions. The programs aren't going to change and branch predictors will never be perfect and caches cannot be any faster without decreasing in size. Wider cores are pointless if the rest of the CPU can't keep them fed, but Intel and AMD are aware of that and both have done a lot of work on their front ends as well.
People forget that Moore's law was taken out behind the barn and shot about a decade ago.
This is also wrong. It's still chugging along, with the only big change is that the costs for the new nodes aren't linear any more and have practically become exponential as well, meaning that the extra transistors we get aren't significantly less expensive.
You could perhaps argue technicality as the newest nodes aren't strictly reducing the feature size, but are instead employing other techniques to cram in more transistors, but we're still getting same effect. If anyone figures out a new SRAM design that allows for greater density, that would lead to significant reduction in die size as caches become larger.
AMDK11
496
441
Did you take this photo you pasted yourself or did you get it from somewhere?
AMDK11
496
441
Do we know exactly what RoyalCore was supposed to be?
It has been suggested (Exist50) that RoyalCore and LionCove may be the same project.
DrMrLordX
23,226
13,304
Enjoy the tears of disappointment and rage of everyone in this thread I will.
Watch Zen5 be significantly faster in SPECInt and electron crap while showing much less improvement in stuff like Cinebench. Everyone will declare their own predictions to have been accurate.
Correct. I missed, or rather did not associate, the C&C abbreviation.
Clearly that stands for Command & Conquer.
Joe NYC
4,228
5,834
why.
ARLs are worthless memeparts.
Only LNL exists.
Any predictions if Zen 5 can match Apple M4 Geekbench 6 score that has been posted, in single thread? They seem to be continuously fudging Geekbanch 6, so not my favorite, but here it is anyway:
M4: ~3800
7950: 3068
gdansk
4,789
8,083
GB6? Only if Zen 5 has AMX. GB5 I think is possible.
Does anyone know if it has AMX?
adroc_thurston
8,597
11,325
Yeah it's not hard, but GB6 is worthless now since you can pump matrix matth subtest with shared accelerators.
Only if it has AMX.
Does anyone know?
It doesn't.
But it has the silliest, coolest AVX-512 implementation ever shipped.
