Page 252 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
SteinFG
743
873
Feels like we'll have full stack with Zen 5 in 2025:
12C (4+8) Strix, binned to 10-12 cores + 12-16 CUs
8C (4+4) Kraken, binned to 6-8 cores + 6-8 CUs
4C (0+4) Sonoma, binned to 2-4 cores + ??? CUs (My guess is 4)
MLIDs leaked slide shows that Phoenix and Rembrandt sre still there in 2025 (so, 9040 and 9030 series), probably as a cheaper gaming option, since they have 12 CUs, and can still compete with intel's
FlameTail
4,384
2,762
Rembrandt can go and die.
eek2121
3,472
5,147
In this world where AMD tried to plough through the market with a subpar architecture only to pull themselves up by their bootstraps with Zen I firmly believe they would have had no chance splitting their R&D brainpower let alone funding.
If Globalfoundries can't break through 12nm on their own, but AMD can develop a good arch on their own, logic would dictate one group is more fruitful than the other. If it were easy enough to throw money at litho wouldn't all the other fabs also be on 7-5-3nm right now? Occam's razor says it all when Intel was the only mass market cutting edge 'foundry' for over a decade until 2019.
Not trying to attack you, but you do realize that one can exist independently of the other while being owned by the same company, right?
Plenty of companies have multiple independent lines of business.
You mean the Eng CPU sample you got only runs on a ref MB that you got along with it, and that ref MB does not allow changing max TDP setting from stock? Yeah, in that case there’s no way of knowing.
Then we can only make educated guesses of the perf/watt improvement at 120W TDP for Zen5 vs Zen4, based on e.g. CPU arch and chip process tech changes from Zen4 to Zen5. Anyone that has any guesstimates?
Finally, if you only got Eng sample, there’s no way of knowing other results from final CPU version anyway either. So that should apply for your other Zen5 perf info predictions too, if you’re basing it on Eng sample testing alone.
AMD likely has not released the microcode required to run the chip in third party boards. Zen 5 is still many months from release, after all.
This thread is in dire need of mod intervention.
I agree, but not in the way you may think. Lots of people are attacking what adroc is saying rather than hitting the ignore button like they should. I don’t necessarily like him, but he should be able to speak just like everyone else.
Reactions: Tlh97 and Thibsie
eek2121
3,472
5,147
What actually has to be said is this:
Cezanne and Lucienne need to die
I can agree about Lucienne, but Cezanne? No way. Zen 3 is a great chip.
I have a tiny little Cezanne mini PC hosting multiple game servers, a Jellyfin server and more. It isn’t even close to the limits despite all of that.
Is it old? Kind of. Is it incapable? Absolutely not.
Shivansps
3,918
1,570
I mean, is mobile Phoenix2 actually better than mobile Cezanne in any considerable way? im not sure if being better in ST justifies the price, develop a new board, etc...
eek2121
3,472
5,147
I mean, is mobile Phoenix2 actually better than mobile Cezanne in any considerable way? because being just a little bit better in ST im not sure if it justifies the price, develop a new board, etc...
Clocks, a slight efficiency advantage, and IGP are the only differences to my knowledge.
If you had to use each of them in a blind test you would not be ably to tell the difference unless you used the IGP or were measuring battery life.
Shivansps
3,918
1,570
Im not convinced yet that the GPU is better in any meaningful way, it is just too small. But battery life will be impacted yes.
Tigerick
941
857
Here comes the competitor of Intel's Lunar Lake, AMD's Kraken Point specificly U -series of Kraken Point. I just couldn't believe AMD don't have ultra-portable solution to upcoming LNL from Intel....turn up Kraken Point U series which are supposedly launching in Q1 2025 is the one. I have listed down the leaked specs and compare to Lunar Lake, seems like Kraken Point wins in almost every parts:-
AMD's U-seriesHawk PointKraken PointLunar LakeStrix PointStrix Halo
(Sarlak)
DateQ4 2023Q1 2025 ?Q4 2024Q3 2024Q1 2025 ?
NodeN4N4PN3B + ?N4P2 x N4P + N3E
Die Size178 mm2??225 mm2?
TDP15-30 W15-30 W?17-30 W15-30 W?120 W ?
CPUZen 4 8PZen 5+5c 4P+4ELNC+SKT 4P+4EZen 5+5c 4P+8EZen 5 16P
Threads161682432
L3 Cache16 MB16+4 = 20MB ?8 MB16+8 = 24MB16+16 = 32MB
Base Freq3.3 GHz????
Turbo Freq5.1 GHz????
GPURDNA3 12CURDNA3+ 8CUARC 8 XERDNA3+ 16CURDNA3+ 40CU
SP76851212810242560
ALU7681024102420485120
GPU Speed2700 MHz3000 MHz ?1850 MHz3000 MHz ?2500 MHz ?
FP32 TFlops4.1 TF3 / 6.1 TF3.8 TF6.1 / 12.3 TF12.8 / 25.6 TF
AIE (TOPS)165030 ?5050
  • LNL has one advantage that is ability to scale down to 9W with fanless design. However, in PC market I am not sure that make business sense. Even ZenBook Duo comes with two fans to cool down MTL-H CPU.
  • Kraken Point essential is a cut down version of Strix Point with lesser e-cores and half of CU. There are going to have H and U versions. U-series with lower TDP should compete well against LNL with lower clock speed.
  • With HT, Kraken Point should support double threads compared to LNL. As for GPU performance, it depends on AMD RDNA3+'s DI implementation.
  • It is rough comparison table, but at least we know how AMD's answer to Intel's LNL.
  • I thought of putting ARL-U to compare with STX, but the specs are so low what is the points ;) . IFS really needs to catch up...
SteinFG
743
873
It's a shame that AMD doesn't have any chips in anything ultra-portable, like handhelds 😢 /s
Ryzen Z1 and Z1 extreme can already scale down to 9W
StefanR5R
6,838
10,983
I find it irritating when folks take Intel's "P" and "E" terminology and apply it to AMD CPUs. Remember, this terminology denotes two very different lines of core microarchitectures of Intel's. AMD does not mix core architectures in their CPUs, and presumably won't do so either in Zen 5 CPUs. With Zen 4, AMD just introduced two different physical designs of one and the same microarchitecture, and the effects of this are different from what Intel is accomplishing with its P+E products and E-only products.
Kraken Point essential is a cut down version of Strix Point with lesser¹ e-cores² and half of CU.
This could be phrased as "¹fewer ²dense cores" or "¹fewer ²compact cores", for example.
Markfw
May 16, 2002
27,393
16,236
Exactly. The only difference in the AMD dense and regular cores is cache size and speed. The performance is close and the usability is identical . Example, they both have avx-512 for AMD. Intel used to have it only on the P cores, but is now totally gone or disabled.
TESKATLIPOKA
2,696
3,260
NodeN4N4PN3B + ?N4P
Threads1616824
Base Freq3.3 GHz???
SP7685121281024
ALU768102410242048
FP32 TFlops4.1 TF6.1 TF3.8 TF12.3 TF
  • LNL has one advantage is ability to scale down to 9W with fanless design. However, in PC market I am not sure that make business sense. Even ZenBook Duo comes with two fans to cool down MTL-H CPU.
  • With HT, Kraken Point should have double threads compared to LNL. As for GPU performance, it depends on AMD RDNA3+ DI implementation.
  • I thought of putting ARL-U to compare with STX, but the specs are so low I am not sure what is the points ;) . IFS really needs to catch up...
Wrong ALU count and TFlops for Hawk Point.
Timorous
1,989
3,918
Cache size is independent. In Bergarmo the L3 cache per core is lower for die size reasons. In PHX2 the L3 cache amount is the same as PHX1 and the 6c variants get the same L3 per core.
The only difference between the dense and the standard cores is clock speed.
