Page 137 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
adroc_thurston
8,118
10,883
Joe NYC
4,063
5,611
I can agree with more than a single SKU, but will they really go down to 8 cores?
Yes, you could use only a single CCD, but the reason why I am sceptical about that is the existence of Strix Point. That one will have 4 Zen5 + 8 Zen5c cores, so Strix Halo with only a single CCD would be slower in the CPU department.
I see a possible lineup like this:
Strix Halo: 16 Zen5, 40CU RDNA3.5, 256-bit LPDDR5x
Strix Halo: 14-16 Zen5, 36CU RDNA3.5, 256-bit LPDDR5x
Strix Halo: 12 Zen5, 32CU RDNA3.5, 192-bit LPDDR5x
Strix Halo: 10-12 Zen5, 24CU RDNA3.5, 192-bit LPDDR5x
Strix Point: 4+8Zen5(c), 16CU RDAN3.5, 128-bit LPDDR5x
Strix Point: 4+6Zen5(c), 12CU RDNA3.5, 128-bit LPDDR5x
Strix Point: 4+4Zen5(c), 8CU RDNA3.5, 128-bit LPDDR5
8 full Zen 5 cores with their full L3 is more than capable enough for a laptop. The CCD may have a V-Cache option as well.
16 cores would be just for halo effect, just for the longest bar on some MT benchmarks, not for anything super practical.
I think the main point is to integrate dGPU level graphics at lower cost and lower power consumption than adding dGPU.
Let's say for gaming notebooks. 8x Zen 5 cores + full graphics capability would serve a decent sized niche.
Glo.
5,930
4,991
Product like large APU is not only for laptops.
Its a mobile first design that can scale up, not down. Most of it however will go to laptops, obviously. But use cases for product like Strix Halo are more than just laptops.
If anyone remembers what I was talking about few months ago that there is coming paradigm shift in mainstream computing - those people should know what products like Meteor Lake-P and Strix Halo are for.
Joe NYC
4,063
5,611
Yes but it's more SKUs. Annoying.
That is true, but worth it. The cost saving measures of integrating CPU + dGPU + DRAM (from 2 dedicated sets) all into one package should be a good value proposition for OEMs. Should enable them to cut their own design and validation costs and also BOM.
At the same time, it would shift more of the notebook BOM to AMD.
Joe NYC
4,063
5,611
Depends on how much cash AMD is willing to pour to prop the segment into viability.
Area where AMD needs to improve. AMD may release a leading product in a segment and still not get past 20% market share in the segment where it has a leading product
Joe NYC
4,063
5,611
I agree with that. Most office desktop users can live just fine with Mini PCs powered by mobile CPUs.
I think Strix Halo would fit this market quite well.
TESKATLIPOKA
2,696
3,260
I didn't say 8 Zen5 cores won't be capable enough per se, It's more about how would you price It.
What price would you set for 8 Zen5 + 40CU RDNA3.5 vs 12 Zen5 + 32CU RDNA3.5
or 4+8Zen5 +16CU RDNA3.5?
Then there is still the question of how good would 8 Zen5 be against the competition?
jpiniero
17,097
7,485
Even AIOs these days are IGP only. Strix Halo seems only really suited for gaming laptops. Strix Halo is going to be too expensive for any other segment.
adroc_thurston
8,118
10,883
Is that the name of the new socket?
Yes.
then I would expect the same also for the CPU tiles
They don't need to.
It's an inherintly niche product, even 5 design wins would be something.
There is more to managing a profitable company than pleasing one GM obsessed analyst at CC (Stacy Rasgon)
Eyyyy Stacy is a cool guy. Shush.
No, it's for premium 15/16" thins first and foremost.
Joe NYC
4,063
5,611
If they are willing to use N3e for SoC, then I would expect the same also for the CPU tiles. At least, I am sure this won't be cheap.
I think we are at the point of when the Zen 5 CCD is entering volume production in the fabs. Way past the time to make any changes.
The question is if AMD made a dedicated CCD for Strix Halo or just modified some metal layers to be compatible with Fan Our packaging.
I think the likelihood is that this is not a fully redesigned CCD that stripped out the GMI lins from the die area. Most likely just redesigned metal layers, same as what AMD did with Zen 4 for Mi300.
Cost is definitely a concern, for parts that could be on N6. But I think this is AMD trying to create a new segment, and this is just its first implementation. Follow up products may be more fine tuned...
adroc_thurston
8,118
10,883
This.
IFOPs go out, USR goes in.
It is a redesign (not a new floorplan, just a tiny link swap).
Atta, that one does HB with tiny pitches that allows to connect ingest ring SDP directly to the underlying fabric tile.
No can do that with 2.5D pkg.
Joe NYC
4,063
5,611
I don't think AMD will be going much below full 40 CUs. 1 vs. 2 CCDs is going to be the main segmentation.
I think 8 Zen 5 CCDs with the strong GPU capability could be the sweet spot for gaming capable notebooks.
Glo.
5,930
4,991
Strix Halo should compete in GPU perf terms with 4050, 4060 and 4070 laptop GPUs.
So it should yield 3 SKUs.
Reactions: Joe NYC
Joe NYC
4,063
5,611
Integrating DRAM in package would be a nightmare scenario for Stacy, since it would lower GMs. But at the same time increase AMD revenue and EPS, even if AMD can charge only a 5% mark-up on that DRAM.
So good for shareholders, and Lisa is a bigtime shareholder...
Joe NYC
4,063
5,611
This.
That seems like quite a serious effort. For something that will not right away be a volume product.
So, in theory, eliminating GMI / IFoP from both sides can result in some die area savings and those savings alone can pay for Fan Out packaging...
It should have some small to modest improvements in number of areas when it comes to memory accesses, their latency and power overhead.
Glo.
5,930
4,991
Itll be cheaper than implementing Intel and Nvidia GPU combo.
In terms of engineering effort, complexity of the boards, and the product, itself.
So why not use it, even for premium-mainstream products?
Abwx
11,986
4,946
Not the subject of the thread but i think that she got way way too much for the time she s at the helm of AMD, not a good thing if one want a still performing CEO.
For such a reward AMD should be at 50bn yearly revenue at least, wich is far from being the case.
adroc_thurston
8,118
10,883
No it's just doing more effort for negligible packaging area gains.
PHY swaps aren't quite that.
No you stick a fat PHY in and let it run lowest link states outside of heavy loads.
Reactions: Tlh97 and Joe NYC
TESKATLIPOKA
2,696
3,260
N3E vs N5 provides 32% reduction in power draw at ISO performance.
This is pretty good If you think about It.
If we say that 7800XT had 225W just for the GPU alone, then 2/3 of units would be 150W, further reducing It by N3e process would result in 102W at 2430MHz.
Then there is still the possibility of higher clocks by fixing what went wrong in RDNA3, It really could end up faster than N22 while consuming a lot less.
