Page 134 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
adroc_thurston
8,118
10,883
but I don't know if they use SoIC or some micro-bump tech?
SoIC is now both bump- and bumpless-3D.
In any case, MI300 is SoIC-X 9um for everything.
It is a specialized cpu chiplet
Yea.
I have to wonder if they would make use of this somewhere else though
No.
So are they really only making this special chiplet for MI300?
Yes.
Perhaps this will change with Zen 5
No, Zen5 brings quite literally 0 system design changes for parts not named Strix-Halo.
It would be nice to be able to get essentially 1/4 of an MI300 as a desktop or mobile part with up to 3 cpu chiplets
Man you're kinda-sorta-almost getting it.
Wrong focus though.
AMD seems to not be planning on using much stacking, other than v-cache, for mainstream parts.
Well, 3D stacking is decidedly not mainstream, yes.
Saylick
4,106
9,597
Yea, all the system design changes are loaded into Zen6.
STX-halo is the only Zen5 part that gets the shiny new blingee (2.5D fanouts, USR links, SLC, yaddayaddayadda).
More about how Zen6 looks.
Surely Zen 6 can't be cheap with all this fancy packaging tech. Heck, @adroc_thurston , wasn't it you who said that MTL was going to be pricey for Intel to manufacture because it uses so much packaging?
Joe NYC
4,063
5,611
What's the difference in latency between MALL SLC and Zen L3, if it is good enough for GPU, but not good enough for CPU?
TESKATLIPOKA
2,696
3,260
Strix Halo looks like an interesting product, although It has relatively weaker GPU part.
CPU with 16 Zen5 will be comparable to even desktop, limited only by TDP.
On the other hand 40CU GPU is not that much, especially when we don't know the clockspeed. To be on par with N33, It would need ~2.1-2.2GHz.
Can It clock that high or even higher while also feeding 16 cores with 125W TDP?
Reactions: Tlh97 and Joe NYC
TESKATLIPOKA
2,696
3,260
Yea, RDNA3 was made to run nutso speeds and the thing hasn't been canned so nutso speed it is.
I hope so. This would bode well also for Strix Point, but there BW could be a problem.
BTW, you meant RDNA3.5, right? Because RDNA3 is not achieving nutso speeds.:D
Timorous
1,985
3,907
RDNA3 can do nutso speeds at nutso power draw. I presume 3.5 just fixed whatever it was that prevented nutso speed from running at sane power draw.
I also presume 3.5 would not have been needed at all if 3 hit it's original targets.
soresu
4,232
3,723
I see R3.5 the same way I see Vega 2.
R3 was just malformed.
IMHO their priorities are Zen and CDNA now.
RDNA dGPU is a distant 3rd priority behind APUs and the continuation of their console contracts.
Anyone compared Phoenix Point to N31/32/33?
Reactions: Tlh97
A///
4,351
3,160
RDNA3 based products didn't show us a great showing compared to RDNA2.
Unless RDNA3.5 in Strix Halo(Point) shows us some significant improvement in perf/W, then RDNA3 won't be remembered in a positive light.
I remember you warning me against buying RDNA3 because I was set on getting it.
TESKATLIPOKA
2,696
3,260
Sorry, I don't remember. From AMD I would consider only 7800XT and can't say I am impressed.
Duh.
STX-halo has no reason to exist without banger iGP perf.
It will have the best IGP performance, but the question is how high is that performance and at what TDP.
For example:
If the TDP is 125W for the whole chip and the 40CU IGP can keep 2.1GHz clockspeed in other words N33 performance level, then I am not sure If It's that impressive.
6nm 32CU 7600M XT with 2.3GHz gaming frequency consumes 120W TGP(GPU+memory).
4nm 40CU IGP at 2GHz would consume 80-90W(IGP), 35-45W reserved for the rest.
If It can manage higher frequency, then of course It will more impressive.
TESKATLIPOKA
2,696
3,260
The thing is designed for above-AD106 levels of perf, it's a lot-lot faster than N33 (or should be).
That sounds good, but I want to see some tests first.
Based on the supposed memory subsystem 256-bit 8500mbps LPDDR5x + 32MB cache, it is comparable to what N33 has and memory is shared with the CPU.
It's not N4.
Then N3.
Not made to run those speeds *at all*.
For 4060Ti level of performance, It would need ~2.5GHz.
For 7700XT level of performance, It would need ~3GHz.
I am not taking into account the memory subsystem.
For an all-rounder like Strix Halo, I am surprised they didn't save some space by using 8 Zen5 and 8 Zen5c cores, but with >100W TDP maybe It wasn't worth It.
Reactions: Tlh97
Fjodor2001
4,489
708
Ok. So people are not complaining about the high power consumption on latest generation desktop CPUs. Right. Then why is it being brought up as a drawback for Intel compared to AMD, that Intel has higher power consumption?
And why are many users intentionally changing BIOS settings from 170W TDP to 120W on Zen4 CPUs, to get lower power consumption, while not lowering performance much?
It's a CoWoS'd laptop chip and those LITTLEs aren't for nT spam at all.
No, the Apple M2 Ultra is not used in laptops. It's a b.L chip intentionally for desktops/workstations by Apple. So there's a reason they used b.L for desktop too. It's simply a better design. Both for laptops and desktop.
Because most people doing DYI PCs do it for gaming, and gaming perf doesn't require 16c parts
Then why is AMD making 16C AM5 desktop CPUs? They should go for only 1-8C CPUs with Zen5 on AM5. Then 8C+ on Threadripper SP6 only.
Poverty segment where costs matter.
So all laptops are poverty segment? You do know many laptops are more expensive than desktops right? E.g. Mac Book Pro for $2000-2500. And yes, intentionally with b.L, since it's a better design.
And have you noticed how many poverty desktops there are? Why is AMD not using b.L for them, if you claim b.L is only used to lower cost?
Reactions: JustViewing
adroc_thurston
8,118
10,883
People have to justify their purchases.
It's a two M2 Max laptop chips glued together over a InFO-L substrate.
Marketing.
They're niche but winning the halo is nice.
That is what sells yes.
YES!
Always were, are, and will be!
I do procurement, you don't have to tell me that.
The chip cost there is tiny relative to machine total BOM.
It uses the same 4c Blizzard cluster as everything else Apple A15 gen.
They're not spamming it like Intel.
You can pay for that in desktop.
Because desktops can pay.
Reactions: Tlh97
