Page 112 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
19,218
PROM21 will have a long life yes.
I suppose the OEMs love that as it means less engineering/validation work for them. Whatever work they have done till Zen 5 launch and whatever lessons they learned after launch, they can now sit back and print money, at least on the chipset side.
Det0x
1,490
5,117
Eh there certainly will be new mobos but yeah.
We are already seeing that on Zen4
Current 1DPC motherboards are having a much easier time reaching 8000MT/s and above while 2DPC generally seems to stop at ~7400-7600MT/s (if you require full stability)
Next generation boards will have a increased focus on memory traces for higher speeds
Pretty sure X670E GENE is having a boom atm
Det0x
1,490
5,117
No that's an inherent DDR5 limitation.
What is ?
Currently there is a motherboard limitation for high memory speeds on the AM5 socket
(such as nonworking multipliers above 80(40) on the last 3 AGESA's)
Come Zen5 release you can bet your behind that we get a new "X770E" AM5 chipset with support for higher memory speeds as one of the major selling points over X670E
Det0x
1,490
5,117
DDR5 is inherently slower with longer traces required for 2DPC fanouts.
You are missing the forest for the trees
Noone is arguing that a 2DPC layout will match the speeds a 1DPC layout can achieve, on average
But that does not have any bearing on one of the major selling points for the next generation "X770E" AM5 motherboards will use over current X670E/B650E, memoryspeed going forward will get much more focus
soresu
4,252
3,756
Speaking only for myself and a minority of others, some of us need a LOT of cores, and fast ones, but not as much PCIE lanes and other functionality of TR or EPYC, and we don't want to pay for it. There is a market, not sure the total size.
Mmmhmmm - in the words of the great Johnny 5....
Ajay
16,094
8,116
@igor_kavinski So it will be quad channel? Coz I don't see why they will go from four dimms to just two universally.
So, problem number one:
From Altium's website (PCB design software) : DDR5 and DDR6 take the top-end DDR4 data rate and double it again (and another doubling in DDR6) by making buses faster, rather than wider. You’re still dealing with DDR4 routing challenges in terms of laying out parallel single-ended nets, but these channels are much shorter. Buses will also run fast enough that typical channels will usually be electrically long, so bit errors will be dominated by insertion losses along interconnects.
Having insertion loses from two DIMMS on the same channel would just ruin the signal that the IOD will see. The classic 'eye' shape we see in high speed signals would collapse and render the bit level indeterminant. The problem that I see is that with only 1DPC, the bus width will be halved, so even when running at twice the frequency, the data rate will not change. So, something else will need to be changed or , for example, a dual CCD Ryzen CPU will be bandwidth starved. A very large SLC on the IOD maybe?
Edited.
SpudLobby
1,041
702
Well, if this is true, and it looks legit for now - even less competition for AMD in the performance market with Zen 5. 1600 @ 3.4GHz is higher than the X3 but barely. TBD on power. There's also further delay apparently.
Then we've got this. Almost certainly due to anticipated lower demand IMHO, at least at the prices they can afford to charge - BOM is indeed going to rise now that Intel's ramping i4/i3, using TSMC's leading nodes, etc.
https://twitter.com/dylan522p/status/1693981897309761657
It's AMD's to lose to some extent with Zen 5 in mobile client parts.
Doug S
3,850
6,804
I'm pretty skeptical of that. That would be worse than the original Nuvia was projected to be. Though I guess if anyone could take their work and screw it up, it would be Qualcomm!
