- Mar 3, 2017
- 1,779
- 6,798
- 136
Getting close to M4. Zen 6 could catch up to M5 in ST on desktop. If zen 6 laptop parts can hit ~3800 at least on N2 that would be amazing.Overclocked 9850X3D geekbench 6 run for those interested
ASUS System Product Name - Geekbench
Benchmark results for an ASUS System Product Name with an AMD Ryzen 7 9850X3D processor.browser.geekbench.com
Good interview
That's my question. I suspect that RDNA 5 is a notable XTOR count increase per WGP, and a much smaller RDNA 3.5 iGPU is still more than capable of being effective in poverty markets. The 8CU in KRK does a good job keeping up with the 12CU unit in HWK on actual game performance. We see that with FSR3.x, it's enough for most games to drive a 1080p display well enough to be usable. Even the 4CU unit in KRK2 isn't awful.I don’t want an ASUS tuf. What now?
why are they porting RDNA3.5 to N3 then?
Why would poverty markets need N3? They could keep on selling N4 RDNA3.5 in those areas.a much smaller RDNA 3.5 iGPU is still more than capable of being effective in poverty markets.
Cheapeast IP they have.why are they porting RDNA3.5 to N3 then?
CPUs matter. GPUs do not.If Zen5 isn’t good to port over to N3 then RDNA3.5 isn’t either. A waste of time.
You know people don’t have to justify whatever AMD does as sane. If Zen5 isn’t good to port over to N3 then RDNA3.5 isn’t either. A waste of time.
Is there any advantage to doing this? Why doesnt AMD just keeps RDNA3.5 on 4nm like Intel (18A for CPU and N3E for GPU).Since Medusa 1 die is N3P, then AMD is obviously porting RDNA3.5 to N3P.
Adding packaging overhead to mainstream parts is idiotic.Is there any advantage to doing this? Why doesnt AMD just keeps RDNA3.5 on 4nm like Intel (18A for CPU and N3E for GPU).
DDR5-4800 vs. DDR5-6000 Performance With The AMD Ryzen 7 9850X3D In 300+ Benchmarks
It's an 8Q cadence with client SoC uncore being the lowest priority (GPGPU > server > GPU > client SoC).Which is the reason AMD should be iterating the uncore annually until they catch up.
It is closer in SIR2017.Battle of the 128 core CPUs. Granite Rapids vs. Turin full cores. I thought Granite Rapids was closer, in performance:
Yep, Intel no longer has a high speed mem advantage as that is equalised.Mind you, this is babymode.
Venice is the first Actually Expensive EPYC and it'll show you how winning™ looks like for realz.
Mem speed is whatever (just don't triple stack DDR PHYs and you'll hit relevant ones).Yep, Intel no longer has a high speed mem advantage as that is equalised.
What is H445 and H350??So, Zen 5 can hold its on in the CPU core area, even on N4, but the uncore stinks.
AMD core power results are questionable.So, Zen 5 can hold its on in the CPU core area, even on N4, but the uncore stinks.
AMD Zen 5 strix point and gorgan point skus.What is H445 and H350??
Just saying as there were some benches that liked MRDIMMs.Mem speed is whatever (just don't triple stack DDR PHYs and you'll hit relevant ones).
I mean node and packaging and cache ratios and the uncore.
Venice is really $$$ but man does it win some.
What matters is CAGR, make a big enough leap every 2 years and all is well.Well, the results show it. AMD can achieve some competitiveness, briefly and then, with no follow up, loses it.
At this pace and with this attitude, AMD will be #5 of the 5 notebook vendors. Behind:
- Intel
- Apple
- Qualcomm
- NVidia
They all invest more and they all take the market more seriously.
Is there any surprise then how the notebook OEMs went exactly as much on the limb for AMD as AMD goes out on the limb about the notebook market?
Well, I have a pair of 9755's, just not in the same motherboard, and they rock ! And destroy everything else I have, and that's saying something.Battle of the 128 core CPUs. Granite Rapids vs. Turin full cores. I thought Granite Rapids was closer, in performance:
