- Oct 13, 1999
- 22,377
- 2
- 81
Update, now that I've lived with the case for a while...
The side panel screw holes are threaded differently from normal case screws, so you can't just slap on your favorite fancy anodized thumbscrews. If you want to use thumbscrews, you have to use what it came with, or you need to re-thread it.
The case suffers a tiny bit from fan/HDD vibrations. Not nearly as bad as many other cases, but the Antec Solo had basically zero vibrations due to the special HDD mounting and the anti-vibration panels it came with. Sometimes the new system seems to have a cyclical hum.
If it is really quiet and I lean back (system under desk), I can definately hear the system running. HDD seeks can be heard. Otherwise, when I'm watching anime or gaming it is pretty unobtrusive.
I was getting used to kicking the power button on the Antec case with my big toe to power it on. I find that I sometimes walk up to the system and get ready to kick it... but the power button is on top.
The top buttons/ports are handy, except I also use the top of my computer to hold an external HDD adapter.
Fresh install of Windows on an overclocked quad core with a VelociRaptor = really snappy performance.
Even with the extra noise I'm pretty pleased with my upgrade. Note that for the past few years I've been on a "quiet freak" streak, so while I call this new system "noisier than the other one" most of my friends would consider it pretty darn silent.
