YOUR safe operating temperature?
This was a great thread. I know its ancient now, but I think it was worth resurrecting.
The info from RGE was excellent, but it seems most ignored it (even while giving him great kudos). This must be an example of the "metric system" attitude he is talking about.
How can people possibly say they are going to choose some arbitrary value to treat as "max" when they dont know the accuracy of the reading itself?
TJMax is unpublished. That is a fact. There is no reason to assume that the published 100C for MOBILE procs is relevant to desktop procs and, in fact, a good bit of reason to assume it actually isnt.
TDS reports distance to TJMax and nothing more. If TJMax is a true unknown, you CANT say "Ill NEVER go above 70C!!!" because, without a Fluke, you have NO IDEA what the real temp of your proc is.
The only realistic measure is to say, "Ill never allow TDS to be greater than X". But to me, if TDS=0 is where throttling occurs, than having some mental need to be 20, 30, or even MORE away from TJMax is a kind of a sickness. LOL... No offense.
I mean really... Above someone said that "the temperature readings we get at home are a fair estimate" Actually, they arent. Not even remotely. That was RGE's entire point. They are a CALCULATED NUMBER based on pure assumption.
Intels "spec" is merely for TCase Max and is a guideline, again, as RGE said and even then, there are "official" reports of multiple versions of that truth based on rev, stepping, or whatever. "TCase Max" isnt even an absolute. You'd need to really check exactly what the value is for your specific part IF you cared, but I dont see how its relevant at all really.
For annecdotal evidence, Ive had an OC'd QX6700 running at as close as TDS=9 or 10 nearly 24x7 since it was released and everything is absolutely fine, so most of you guys shooting for TDS=30 or 40 or more (soon you'll need to put it in a fridge as TDS will be greater than the actual operating temp, I guess) will be all set with procs that last probably until after you're long gone 🙂
60ºC at most, and that would be extreme. My CPU idles around 40 at day, 35 at night. And I think under full load it goes around 55-57ºC.
My Xeon X3210 @ 3.52 w/ 1.425v runs idle at 47,49,44,44 and loads it hits up to 74c which I'm not to happy about but the thermal spec is 85c. I have just really never worried to much about my processor temps, I worry more about voltage.
E8400...the highest i feel comfortable with is 65C after that its iffy...although when i started to learn to overclock with my E660 on stock i figured out what temperature monitoring software was...and well it had a 82C load for several hours until i learned that was bad
i am really picky about heat in my system, since if it gets to hot it also starts to heat up my room. even in the winter it can get to 80f or higher in my room, due to having 2 monitors, my computer, and a rather large sub woofer under my desk.
my athlon 4000+ typically runs somewhere between 27c and 34c idle depending on ambient temperature, and up to 44c at load with a high ambient temperature. TCaseMax for my system is rated at 57c so i would say if it gets much higher than that (i voted 60c) i would start shitting bricks and probably reseat the CPU with new thermal compound, or point the 20 inch fan i currently have pointed at myself directly into the case, after completely dusting it out
i miss the days of the athlon XP's overclocked and overvolted to the max and still hovering around or under 50c with a little 80mm fan
those things would never break a sweat
my c2d hit like 78C the other week when it was over 100F outside and i didn't have the aircon on (i was sweating bullets) ended up crashing the system, so i ordered 3 of the most powerfull fans on the market (a must for me, happy with the purchase) great ol' helicopter sound just like my prescott 2.8e was
every since i've made the switch to intel it's been a hot ride, maybe it's just a coincidence tho ...
Deneb + am3 will definately be worth a look when it comes out
Not sure I ever really 'stress' my 3800+ cpu. But highest 'max temperature' cpuid hardware monitor has ever reported, after lot of gaming or other apps, is 39C. Seems rather cool really, obviously I'm not working the thing hard enough. Probably be even cooler in the winter when the ambient is like 8C lower.
I have 75-80C @ full load (30 min prime95-sandra/core temp - real temp) whith a E2160@stock and a E8400@stock / 25-30C ambiant temp , is it normal or should i change the stock HSF?
Is there a rique of stability issues?
Will this shorten le life span of the chips?
It's not really "Full load temp" unless it's done on the most extreme testing, and that's Intel Linpack, you can get the Intel BurnIn Test GUI to really heat up your temp. Intel Burn In Test
I'm running 72c with it even though Prime95 only got it to 66c.
Yeah, Linpack is a real bitch. Getting 63 C with dual Prime, but hitting 86 C with Linpack!!!!!!!!!!!
This made me change my cooler, then the fan of the new cooler ( S1283 ) , but I still hit 86 C at 1,45 V and 4 ghz, no matter what I do!
The thing is, that IntelBurnTest heats your cores to a level that you wont get in real life situations like gaming, folding, compressing and so on.
