You have a plane and a conveyor belt.
Page 34 - Seeking answers? Join the AnandTech community: where nearly half-a-million members share solutions and discuss the latest tech.
JujuFish
11,455
1,057
Originally posted by: SparkyJJO
The plane increases it's thrust and the wheels begin to rotate. The belt compensates for the rotation of the wheels in reverse, as in the belt moves in reverse exactly as fast as the wheels move forward.
meaning the plane physically doesn't move anywhere....
And if it matters, it's a nice sunny day and you have good tires, so you get perfect traction on the belt at all times.
And that doesn't matter at all because.....
Your plane also happens to be very powerful and you can give it as much thrust as you like, but the source of thrust is at the back of the plane so it never provides airflow over the wing.
There is the deciding factor. No airflow means no lift, and no lift means the plane won't take off.
:roll:
Reading comprehension is not your forte. It's saying that the thrust itself doesn't provide airflow over the wing as it would if it were a propellor plane.
SparkyJJO
13,357
7
:roll:
d'oh! :eek:
blahblah99
2,689
:roll:
I gave up after the last post... it's like going back in time trying to convince the 1300th century folks that the world is round and not flat.
CallMeJoe
6,938
Aerodynamics must not be your forte. Recip, turbo prop or jet, engine wash over the wing is a negligible part of wing lift. The fraction of the wing affected by the engine wash is not sufficient to provide any significant lift. Look at a Piaggio P180 Avanti or a Beechcraft Starship. Both turboprops, both pusher props (no significant prop wash over the wings) and they both fly very nicely.
NanoStuff
Banned
Mar 23, 2006
2,981
Originally posted by: mugs
Originally posted by: NanoStuff
Originally posted by: techs
Geez, hasn't anyone heard of Isaac Newton?
For each action there is an equal and opposite reaction.
Brilliant man, perhaps if he was still alive he could make sense of this for you. Like you said (or he said, any way you want to think of it), "equal and opposite reaction".
Action1: belt moves backwards
Reaction1: plane moves backwards
Action2: plane's thrust moves plane forwards
Reaction2: plane moves forwards
Action1 + Action2 are opposite thus cancel eachother out
Reaction1 + Reaction2 are opposite thus cancel eachother out.
Wait - do you actually think the bolder part is true? I'm not quite sure if I've read your reasoning on WHY you think the conveyor belt can possibly match the speed of the wheels and keep the plane stationary. The only valid explanation for why the plane would not be able to take of is that the wheels would explode due to the infinite acceleration. If you think that it is possible for the conveyor belt to hold the plane in place while the wheels are intact, you are wrong. It is not possible. That is proven by the fact that planes are able to move on solid ground. To the plane there is no real difference between moving on a treadmill and moving on solid ground (until the wheels explode/melt/whatever).
[/b]
The plane can move forward on solid ground because solid ground is NOT moving backwards. The world is rotating and it's taking everything with it along for the ride. If you're out in space, the world is one big conveyor belt. If you accelerate a plane on this huge conveyor belt, the plane moves forward on the conveyor belt, and if it's capable of moving fast enough it will be stationary to the observer in their little space ship. In order for the plane to appear moving forward to the observer, it would have to move twice as fast as the world's rotation, which would require a hell of a lot more energy. And yes I'm aware it's a terrible explanation, but I'm running short on analogies. :)
JujuFish
11,455
1,057
The plane can move forward because it doesn't depend on the wheels. It doesn't drive forward like a car. Whether the ground is moving or not makes no difference unless it's moving at impossibly fast speeds.
NanoStuff
Banned
Mar 23, 2006
2,981
As long as the plane is on the ground and you assume there's traction, yes it does.
JujuFish
11,455
1,057
I would like to make a $100 wager with you that it doesn't.
NanoStuff
Banned
Mar 23, 2006
2,981
I'd love to take you up on that wager if we can agree as to the precise definition of driving in this context, which ofcourse I'm sure we'll be incapable of doing.
JujuFish
11,455
1,057
A rough definition: A means of moving forward through applying a force on a wheel to turn them, with friction between the ground and wheel preventing the wheel from slipping.
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
Wow, I can see why this thread has gotten so long!
And, it's all the fault of the OP who thought he was wording his post cleverly enough to remove any ambiguities.
1. Those who say the plane can't move forward are, in a sense, correct. For if the plane was to move forward, we'd have a paradox. The conveyor *cannot match the speed* of the wheels on a forward moving plane, unless the wheels are skidding. People keep pointing to "if the plane is going 100mph, then the conveyor will be going 100mph in the opposite direction and the wheels will simply be spinning at 200mph." No, the OP said the conveyor matches the speed of the wheels, not the speed of the plane. 100mph doesn't equal 200mph, except in those trick proofs that require division by zero. :p :)
In other words, the speed of the wheels = the speed of the conveyor + the speed of the plane. Since conveyor speed = wheel speed, then logically, plane speed = 0. Anyone using that sentence as the basis of claiming the plane doesn't move is correct. You can't ignore this important fact. But, unfortunately, most of the people who have come to this realization don't quite realize the meaning of it. It's not a matter of the conveyor keeping the plane in place... it results from an impossible constraints on the problem.
2. If the conveyor matched the speed of the plane, rather than the speed of the wheels (which is impossible), then the plane would indeed take off, with the speed of the wheels always double the speed of the airplane as it accelerated down the runway. (assuming no slippage of the wheels)
Now, for those who are saying that a spinning conveyor can keep a jet from moving forward (I've already established that the constraints given by the OP are impossible), try this at home:
Turn on a treadmill... set its speed to 10mph, but keep it level. Put on a pair of rollerblades. Skate across the room at 6 or 7 mph. Hop onto the treadmill while moving forward. Note that the treadmill does *NOT* stop you from moving forward, even though it's moving in the opposite direction at a speed greater than you're moving forward.
NanoStuff
Banned
Mar 23, 2006
2,981
That seems to work, however there's really no way to settle the dispute as we both apparently have a different understanding of the situation. Damned if anyone can convince one or the other of the 'truth' whatever one may believe it to be.
JujuFish
11,455
1,057
Okay, since you agree, somewhat at least, tell me how a plane on water takes off? There are no wheels. Nothing is spinning. Yes, they do take off. Why? Because planes do not depend on wheels to move.
NanoStuff
Banned
Mar 23, 2006
2,981
I was gonna clear up the angular/forward momentum complication of the wheels, but I noticed the problem well into the thread, I figured editing it at that point would create more confusion than was already present. Not necessarily a bad thing though, now we have two problems to work with, even so we still can't agree on a conclusion even with the same interpretation.
NanoStuff
Banned
Mar 23, 2006
2,981
If the plane has no wheels it cannot possibly depend on them to move :)
A plane with floaties will take off because it does not hold traction with the water, so the speed of the water underneath the plane; whatever it may be, could not be directly proportional to the speed of the plane.
mugs
48,920
46
[/b]
I don't even know what you were trying to trying to explain. :confused:
Let me repeat this fact... as long as the wheels of the plane are intact, there is no speed at which the conveyor belt can move that will prevent the plane from moving and taking off.
Look at the friction formula I posted before. It does not depend on the speed of the wheels. The only things holding the plane back are friction in the wheels and air resitance. Neither of those differ between when the plane is on the treadmill and when it is on solid ground.
JujuFish
11,455
1,057
That's because you think a plane acts like a car.
hellokeith
1,664
Those who are saying wheels are not important or negligible to a plane's acceleration need to visit your local municipal airport. Every once in a blue moon, a pilot will forget to remove the blocks from in front of the tires. Needless to say, the plane goes nowhere even with the prop at high rev's.. and this is a piston engine prop plane which does get some airflow over its wings at a standstill.
Another thing you will notice at the municipal airport is airplanes taxiing down the runway and steering, making turns and such. This is only possible by force applied against the plane by wheels in a non-slippage condition. Prop planes do not vector thrust. So obviously there is a force applied against the plane in order for it to make a left turn to get out on the runway. The wheels are not slipping, they are moving, and there is friction, else the plane would not be able to turn.
NanoStuff
Banned
Mar 23, 2006
2,981
In the given scenario, I KNOW it acts like a car. My challenge is to try and get you to see this.
JujuFish
11,455
1,057
Those who think that a force being applied on the axis of a wheel, and therefore not a torque, is proof that the wheels are not negligible to a plane's acceleration need to take a physics class.
JujuFish
11,455
1,057
*sigh* Sig worthy material here.
