Agreed. It's asking for compatibility issues and gives no advantage to most customers. I'd put x32 on any PC for a client unless they specifically asked for x64 and then only if they understand the potential compatibility problems.I also think that it is a mistake installing x64 on computers used by Ignoramuses and especial when there is kids that use the computers too.
An OS upgrade is NEVER the answer for fixing software issues. That said, she agreed to it. The thing is, knowing she didn't have a clue, you should have stressed the potential downside.
I sympathize with your client issue and don't have any great words of advice. Sorry.
Two of the game discs had 16-bit autorun programs, but they could be accessed by going into the SETUP or INSTALL dir, and running setup32.exe directly.
in two years, if she's still using the computer - would it be better if she were locked out of 16-bit software, or locked out of the new 64-bit software?
I install apps that likely came pre-installed (such as Office, burning suite, etc.), as part of it, then list any that I know about but did not install (usually am lacking media, a key, or something else). If it's something there are free alternatives for, like OOo (LOo?) and CDBurnerXP, I'll install and configure those, and note that they should look for their copy of the previously installed pay/OEM-provided app. If I don't install anything like that, and don't make mention of it, I hear about it later.Perhaps I should ask - for those of you that do computer service, when you do an OS re-install/format, do you also install an (unlimited) number of apps for that person too, as part of the OS re-install process? I generally charge extra for app installation, and consider the OS install job as just that - the OS only. (Will also install drivers, webcam software, and printer drivers, but as far as additional apps, no. Well, other than installing a free AV program like MSE.)
i dont agree with this. im not in the computer repair business but in dealing with my own machines, the most reliable way to deal with a virus, spyware or a malfunctioning machine is the reinstall the os
Reinstall != upgrade.
