what kinds of files should i be looking for.
my computer is going crazy. i couldnt access the internet. my brother remided that last night but when it started doing it this morning i tryed to fix it but the program kept closing itself or moving around the screen.
Setting fire to the cat wont work, trust me. Just unplug it from your connection, and then try to find the offending file that is allowing them to do this.
eakers - go to www.zonelabs.com and download ZoneAlarm - the free version. Install, reboot and set Zone Alarm to maximum security. Then watch what asks to use the internet as Zone Alarm will ask you whether to allow it. If its normal things like Explorer and ICQ, then let them, but if you see anything strange asking, tell it NO.
okay boys and girls it said when i tried to open the program to fix it cuz it broke again that it blocked an unauthorized thing then gave an IP #
could it be an at home thing?
also there is a savenow thing that is running that is new.
maybe i should delete it?
agrrrrh okay the main problem is that when i try to access the intenet no matter what program it crashes.
we fixed it last night.
it started doign it again this morning.
when i tryed to fix it this morning the thinggy that i used moved all over the screen and kept closing its self.
It's your fault. Describe the whole problem in detail and then expect a response worth using. Optimus did mention what to do, which you did. Now what is the problem?
