- Dec 18, 2001
- 24,036
- 21
- 81
Originally posted by: Koing
I just want size and definition. I don't care about strength, but I do realize that will be an after effect.
Well I would hit 10 reps then at a lighter weight. The way your hitting it you will get stronger and add some size but you won't get so cut. Your diet will play a big role in cutting cut.
But different people react differently though. Some will cut doing 6 reps 5 sets other 12 reps 4 sets.
Size I would still hit 6 reps 4 sets. You will get big from this.
Side note I know this is about shoulders but if your not doing squats you won't end up being that big because your not working the biggest muscle groups in your body. I'm sure you will will know something about this.........
I started this thread for shoulders, but if you have anything else to add for the overall workout I wouldn't mind. I started a thread about soreness before and I tried asking about size and reps, etc. but I think that got drowned out and the thread died.
So what should I do... I figured that first I'd increase the size, then I'd worry about defining them more by reducing body fat afterwards. Are you saying that for cut I have to work higher reps with lower weight? Should I do that now or just wait until later after size increases?
