I hate my new CRW-F1 recorder. I have only burned 3 discs and I want my Yamaha CRW3200 back. If I use my CRW-F1 for ripping a cd or to copy a disc image, it will peg my cpu, and pretty much make my computer useless until it is finished. When I burn a disc (I have only been buring @ 4x - burning some music) it SEVERLY hinders my system performance, not on the cpu but on the system bus (as the task manager does not indicate high cpu usage, but things get a little choppy). I can?t play music because it makes my mp3's skip, and it slows down anything I am running. I NEVER had this performance loss on my old system (XP1600, K7 Master Mobo, 512MB PC266, CRW3200, Win2K) but this is just disgusting. This is my new setup: XP2000+, 512MB pc333, KT3 Ultra2 Mobo, CRW-F1, WInXP Pro. Besides from the parts listed, all other parts in my computer are the same. (dvd, 40gb maxtor, sblive 5.1) does anyone have any idea as to what might be causing my system to bog this bad. I mean my p2 450 with 2x burner and 384 mb of ram will perform better when burning a disc. PLEASE PLEASE any ideas would be great.
(disgruntled) bagaki
PLEASE NOTE: i have used winXP with my previous configuation (XP1600+) and it worked smooth. I use Nero 5.5.9.14 and EAC 0.9b4 with LAME 3.92 for ripping. Everything is set to DMA mode and i use the SAME software and all the same system settings.
