virtuamike
92-ish 240SX. Then do a SR20DET engine swap. Sexy 🙂
Don't cloud the issue with facts! :disgust:Originally posted by: Mwilding
It always was and always will be a Mustang LX 5.0
Originally posted by: 5ayle
I've been looking around... what do you guys think of like the older supras or rx-7? I mean the old ones that are like pre 90's i think...
Originally posted by: Marlin1975
Firebird / Camaro
Fast, can handle well, and easy to fix and sup up. BAMM
Nah. The rotaries don't age terribly well. I'd get a used Z over an RX-7 anyday.
boosted rotaries are ticking timebombs... but when it works... not a lot of cars can offer the same driving enjoyment. :heart: the NA rotaries are still running around though... slikmunks has one. 🙂
Originally posted by: raptor13
A motorcycle.
Originally posted by: MercenaryForHire
Reliable
Cheap
Fast
Pick two.
- M4H
Originally posted by: flot
You can pick up a 1990-1992 300ZX for cheap. Very solid engines, not too bad to work on but there is definitely a learning curve.
$5000-6000 should get you a nice non turbo, or a well used twin turbo. Either are good cars - mine has 155k miles on it. (and is for sale for $6k)
I wouldn't really call it a sleeper - the turbos are very quick out of the box, damn fast after $2000 of mods, and if you throw $4000-8000 of mods at them, well, they're just plain scary - but still very streetable. (call it low 14s/ low 13s/ mid 12s, respectively)
Yah, buy a 240 which prices vary for, then do a $5K engine swap (more than he wanted to pay in the first place) and you'll get a car that, while very driftable, is still not that fast and will easily get owned up on by a dsm with an mbc. 240 and SR20= Most overrated car and engine combo ever.
Get yourself an early dsm. Get one that was made before June (or was it July?) of 92. That way you won't have to worry about crankwalk. Fairly reliable car to begin with, AWD, reasonably quick (high, mid 14's) with nothing more than a MBC (manual boost controler), responds well to mods, huge support comunity, etc. All in all their great cars. Very cheap to make fast too. If you can't get one into the low 13's/ high 12's with under 3k (or less) in mods you're fvcking retarded.
Originally posted by: CrackRabbit
Your probably going to laugh your ass off at me, but a L-4 turbo Dodge Daytona, easy to mod, easy to take care of and dirt cheap.
CrackRabbit
Let's try this for a dumb question...
Which DSM's come w/ turbo?
CrackRabbit
Doesn't that have a shelby model?
Firebird / Camaro
Originally posted by: fumbduck
92-94 DSM AWD Turbo (Plymouth laser, Eagle Talon TSi AWD, Mistu Eclipse GSX)
Although for your budget you might be able to sneak in one of the LT1 z28's depending on mileage.
Lt1? WHY, WHY... WHY!!?!?!!?!? that engine is useless compared to an LS1.
