YACT: What is this Tornado thing for your car that's supposed to help improve mileage? Does it work?
CPA
30,322
4
Originally posted by: Encryptic
Originally posted by: CPA
This is interesting because I had a Chevy salesman explain this same type of process on the Chevy Tahoe. Apparently, on the 02 and greater models air comes through around the right headlight and then is collected and channeled to an area where the air was swirled around prior to be distributed to the combustion chamber. I joke not, he stated it provided better performance.
I hope you didn't believe him OR buy a Tahoe.
No and No. I am buying a Ford Expedition Eddie Bauer today, instead. :D
Dedpuhl
10,370
Originally posted by: BDawg
Will yellow duct tape increase fuel mileage and horsepower???
Well, neon lights add about 10 HP, and Japanese stickers add 5 HP. I'm not sure about duct tape...
BDawg
11,631
I suppose we could cut it into the shape of an "R."
Dedpuhl
10,370
Maybe we could just use a permanent marker: V-Tech 4 life!
Windogg
I just put my car in neutral in heavy traffic and let the car behind me push me along.
Windogg
Sukhoi
15,350
Windogg
Hmm, I suppose that would work a bit better than drafting semis! :)
Eli
Super Moderator | Elite Member
8
It's a gimmick.
Skoorb is right in saying that it will most likely decrease performance a bit.
Swirling the air/fuel mix should only be advantageous to carburetored engines, because it helps the air/fuel mix and vaporize. It shouldn't matter with fuel injected engines.
Encryptic
8,885
Egad! Die yuppie scum! :p :D
Howard
47,982
11
Originally posted by: Eli
It's a gimmick.
All fuel/air mixes combust more readily (or should I say, thoroughly) when the fuel is atomized.
Eli
8
It's a gimmick.
Yeah, I know... :p
I was just inferring that since the air/fuel is mixed much closer to the combustion chamber, and the injector should do a pretty good job of atomizing the fuel.. it shouldn't be as much of a factor. But with a carburetored engine, the more swirl you can give the incomming charge, the more even combustion will be.
There are quite a few old small engines that have "swirlers" in the carburetor.
NikPreviousAcct
52,763
My friend Matt got some kind of performance intake and his mpg went up 10 on the highway. I dunno what the product was or what exactly it did, but I'm considering looking into it after I get my carb replaced for my birthday.
Cyberian
9,999
Originally posted by: psteng19
Saw an infomercial about this product, so I looked it up online.
It looks like metal fan blades that goes into your carb/air intake that spins and forces more air into your engine, thereby increasing gas mileage and adding performance?
Anyone use it?
Does it work?
I'm thinking if it does work, they would come stock on every car since it's such a cheap and simple part.
Another link
Devices such as this were advertized in the catalog of J.C. Whitney in the late 1950s.
They didn't work then, and I doubt like hell that they would work now.
