Originally posted by: Zenmervolt
Define "backpressure".Originally posted by: Viperoni
Yet another person who thinks backpressure helps power. *sigh*.
Backpressure itself does not help low-RPM _TORQUE_ (note: not HP), but the faster flow rate cause by a smaller-diameter exhaust system _does_. Now, this same smaller diameter that increases exhaust gas velocity at low RPM becomes backpressure at highter RPM because the engine is pushing more air. So a certain amount of "backpressure" at high RPM is indeed helpful to low-end torque because it increases the exhaust gas flow velocity.
ZV
Backpressure should be defined as the resistance to airflow at a given RPM.
Your statement is correct, of course.
I would gladly trade 10-20% of my engine's torque from idle-3k to increase a similar amount of torque between 4k-6k, but that's a completely different discussion 😉
