YACT: redlining
toph99
5,505
Originally posted by: Ultima
Originally posted by: geno
Atticu5, there's a difference between overevving the motor while accelerating, and overevving due to a missed shift (in a stick car) mainly because if you floor it (for example) in first gear, you'll just bounce off of the rev limiter...shouldn't hurt/kil the car. However, if you mis-downshift into 2nd when you go for 4th, it wouldn't matter what your rev limiter is at until you either put the car in neutral or engage the clutch....a situation like that is like you described, and will most likely cause damage if you shift into a much lower gear at a higher speed than you intended to :)
I thought the transmission would just prevent you from shifting if that gear would be over the redline? I know in my friend's car you can't put it in 1st unless the car is almost stopped.
that just means his first gear doesn't have a synchro.. you can put a car into any gear regardless of speed(except reverse) assuming it can handle it mechanically
Ns1
55,420
1,599
Originally posted by: Lithium381
how the heck do you guys hit redline??!??!?! i don't think i've ever put mine past 4krpm.....i shift at about 2700 sometimes as high as 3k, but dang........how are you getting up so high? that's not good!!!
stick shift y0
geno
25,074
4
what he said :)
LAUST
8,957
Originally posted by: Howard
Haha, you said distributor.
:p
LOL, yeah, WTF is that ;)
Ohhhhh I remember those now... I don't miss em ever since I started programming my own PCM ;)
LAUST
8,957
stick shift y0
LOL... thats funny my Auto redlines at 5600 but somehow I'm able to make it shift at 5800 when I want it to... Hmmm how is that possible y0
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
:p
Well, it's a distributor that has electronically controlled timing advance. It's not terribly old. :p
Though this does remind me that I need to clean and gap the points on my other car. ;) :D
ZV
Zenmervolt
Elite member
Oct 22, 2000
24,514
34
Actually, my car has full synchromesh and it's still possible to "lock out" a gear if you try an aggressive downshift. A 4-2 downshift often requires double clutching.
ZV
