The "mid-year" (what the mid 70's 911's are called) 911's with the 2.7 litre engine should be avoided if you want anything resembling reliability. They are far and away the least desireable of the 911 series.Originally posted by: Panakk
Something that's below 10K. I did look at a 1976 Porsche 911 Targe that looks sweet. Corvette's are nice too.
Originally posted by: NuclearNed
Pinto - the car of champions
Originally posted by: MedicBob
If you are serious 1970 Chevelle SS with the LS6 option. 454 CI of love.
ZV
Depends on how much work you want to do on the car. There's a reason that mid-70's 911's tend to be less expensive than other models. The issue is that, through much of the 1970's most companies were struggling mightily to reach emissions requirements and in most cases reliability, drivability, and power were off from earlier and later years. The biggest issue with stock 2.7's is that the head studs tend to pull out of the magnesuim crankcase, an issue that is compounded by a FI system that tends to run lean, a 5 blade fan instead of an 11 blade fan, and the thermal reactors which caused heat-soaking in the heads. This can all be fixed, but repairing the head studs is expensive. Also, these years of 911 are least likely to be collectible (aside from the 3.0 litre Turbo cars, of course).Originally posted by: Panakk
they one i saw had the 2.7 litre engine so i should stay away from it.Originally posted by: Zenmervolt
ZV
Originally posted by: thedarkwolf
I"m a dodge dart kind of guy but you seem to be more into sports cars so I will say an early 70 240z/260z. They are still rather cheap even in good shape and are great looking cars.
Originally posted by: Crafty35a
240z
