Originally posted by: Nyati13
Like everyone else said.... You just need a new clutch. It probably has the full 200K on it, unless the engine replacement specifically included a new clutch at that time.
I can't beleive anyone would replace an engine and *not* replace a clutch with 100k miles that was attached to that engine.
People do strange things all the time, usually when there is money involved.
Originally posted by: V00DOO
Clutch is gone. $250 -$350 in labor plus parts from an Indy shop.
Originally posted by: krunchykrome
Is the clutch an expensive repair? Like I said, it is a 1998 Escort, 2nd engine, over 200K total miles. But prior to this, it worked perfectly, and the car itself is still in great shape. Depending on how expensive the fix is, I wonder if it would make more sense to purchase a new/used car.
Or maybe it was never suggested to him by the shop that did the work and it never occured to him to get it done. From his original post he doesn't sound like a guy that is into cars enough to have automatically thought of that (no offense intended to the OP).
Nope, I wouldnt know that. I did however install new windshield wipers last weekend![]()
Really depends - anywhere from 400-800 bucks is a good ballpark.
Oh, well there you go then...after such a huge investment you'd be crazy not to fix this minor problem and keep driving it for another 100k miles. :laugh:
I wonder how much of a trade in I could get for this car at Carmax. My friend worked there for a while and he said some guy came in trying to sell a 1990 Integra with like 175K miles on it. He was leaving town for good the next day and needed to get rid of it fast. Carmax gave offered him $50 and the guy took it.
Your clutch is slipping. Time for a new clutch...I'd have them replace the throw out bearing too while they're in there.
You won't get much at all for the car with a burnt out clutch, but if you're planning on getting rid of it anyway, you might just want to write it off instead of spending money to fix it when you'll be selling it soon. You won't re-coup the cost of the clutch job very likely.Originally posted by: krunchykrome
I was planning on getting a new/used car within a year before this this car trouble happened.
Originally posted by: iamwiz82
The clutch is slipping, it needs to be replaced.
Originally posted by: MisterJackson
You had some cred built up on this forum in my opinion......until you admited to driving an escort that is![]()
The car is a 1998 Ford Escort. 2nd engine, over 200K total miles on the car. Works perfectly until recently. Lately, when I put it into gear, I'll step on the gas, and the car revs high, and it does engage into gear, but it accelerates sooo slowly while reving soo loudly. Anyone have any idea what this is?
If you can, do it yourself; it's a bit of a pain, though. Still, labor is insane on clutch installs. For my MR2 (a particularly hard car to work on) they wanted anywhere from $800-1500. I did it myself; spent about $250 for quality parts and resurfacing of the flywheel.
It always boggles my mind that people will replace a clutch and not do the throwout bearing at the same time. It takes EXACTLY the same amount of time both ways, and a new bearing is cheap!
