Originally posted by: Roger
Actually the correct word for this is oil breakdown due to shear forces. An internal combustion engine imparts high shear forces on a motor oil, which is sandwiched between two rotating or sliding forces under load and heat. The molecular structure is essentially torn apart by these mechanical shear forces.
The component of the oil that is affected most by these shear forces is the viscosity improvers. These viscosity improvers allow the manufacturer of the oil to create multi-grade oils suitable for a wider temperature range of operation. The end result of these shear forces is a decrease in the viscosity of the oil as well as a decrease in the viscosity index.
Once a motor oil has sheared beyond a specific point it will not revert back to it?s base structure when it cools down and the shear forces have ceased. Keep in mind also that I am referring to petroleum oils only, Synthetic motor oils are extremely resistant to the detrimental effects of shear forces.
Flash point is the temp at which the oil begins to release volatile gasses which is to say it will oxidize (burn).
Terminolgy is everything in my business Eli 😉
You're exactly right about the Flash Point, and I was going to edit my post to be more technically correct.
And yes, shear stability is more important than flash point, since the shear stability is a measure of how well your oil is going to maintain its viscosity while in use. Not much point in a 30 weight oil if it is going to thin out to a 20 weight after a few thousand miles.
Most manufacturers don't specify their High Temp/High Shear specification, synthetic or petroleum, so you're left to assume it's the minimum, which is unfortunate.
Shear is one of the main reasons I dislike 20 weight oils. The minimum HT/HS shear spec for xW-20 is 2.60. The minimum for 0W-30 through 10W-40 is 2.90.
The minimum for 15W-40 is 3.70. That's a huge difference, and one of the main reason why I chose to use Mobil Delvac 1300 Super 15W-40 in the Camry & truck this summer; It's a petroleum oil, but it has one of the best HT/HS scores of any 40 weight oil, 4.40. :Q
There are 30 weight oils that have excellent shear stability, though. It's about the only good thing about Castrol GTX 10W-30; it scores 3.10.
It sucks that there are cheap synthetic oils. They have the potential to give good synthetics a bad name, since they're only marginally better than only the bottom of the barrel conventional oils.
Your oil knowledge impresses me. I've found that many mechanics wouldn't know engine oil from 3-in-1 oil, and they continue to propagate many of the myths associated with oil. I applaud you for keeping up with the times & educating yourself thoroughly.
