*YACT*motor displacement: can changing a carburetor change the liter statistic?
NikPreviousAcct
52,763
I was talking to my girlfriend's roommate's boyfriend. He's ASE certified through the local college, and is now working on getting certification for body work -namely, paint jobs. Anyway, he's quite familiar with the 2.8L V6 that sits in my 1985 S-10 Blazer and knows exactly how things are configured - this from recent conversations about what to do with it.
Anyway, I told him the year, the make, and the model of the rig and he asked if I had the 2.8l or the 4.3L - so he knows what he's talking about. He also knew that, since I have the 2.8L, he also knew that the 4.3L won't fit if I wanted to change it since the 4.3 is at 90 degrees and the 2.8 is at 30 degrees (or was it 60 degrees???). Blah blah blah.
He asked if I had a 2-barrel or a 4-barrel carb, so I said I had a 2-barrel.
What did he say next?
If I were to change the 2-barrel and it's intake to a 4-barrel and an intake to match, the liter displacement will make the block equivalent to a 4.3L.
Since I'm not the UberCarGod, I didn't question the ASE certified UberCarGod. But, in conversation with Viper GTS, he and I got a little confused. I didn't think it was possible for the carb change to change the liter count, but apparently it can.
Is this true!? :confused:
nik
Kadarin
44,296
16
Nik, it is not true. Engine displacement is a function of the bore and stroke of the cylinders, and has nothing to do with induction.
PsychoAndy
10,735
Um, AFAIK carbs wont affect displacement. CID is a physical calculation of the volume of the stroke and the bore IIRC.
Now the a 4 barrel carb, you will get more power.
-PAB
NikPreviousAcct
52,763
That's what I thought, but threw out that idea when he told me. Then, when Gregg said the same thing, I got confused. :confused:
nik
NikPreviousAcct
52,763
-PAB
Yeah, and worse gas mileage and I might actually not pass DEQ -or so he tells me.
nik
Viper GTS
38,107
433
Exactly what I said.
Viper GTS
Jzero
18,834
Maybe he's saying the 4-barrel carb would give you comparable performance to having the 4.3L?
dirtboy
Can you change the size of a gallon of milk by putting a larger hole on top? Nope. Same with cars.
PsychoAndy
10,735
-PAB
nik
More air, more fuel, more power.
Hey, it worked for the '60's!
And yes, you may lose emissions cert due to the increase in CO2 and/or particulates.
-PAB
NikPreviousAcct
52,763
Viper GTS
Exactly what you were also confused about just like I was when I heard this from someone with obviously WAY more experience than I had. I wasn't about to question someone who can fix anything and everything on the car - but I understand why he'd tell me this...
nik
NikPreviousAcct
52,763
No, I see him saying it. Photographic memories are awesome. :) I very distinctly remember him saying that the size displacement will equal the 4.3L
nik
NikPreviousAcct
52,763
SON OF A BITCH! MAUL'S BEEN CHEATING ON ME? :eek:
-PAB
Haha - :) I hadn't seen him online in a week or so, so I was naturally happy to see him log on to AIM and decided to play it up. :p
nik
Kadarin
44,296
16
Viper GTS
nik
I, too, have met quite a number of people who were mechanically proficient at fixing anything engine-related, yet didn't understand the science behind how engines work and how they build horsepower.
Pacfanweb
13,158
59
Nik,
I don't understand why he would tell you that. It's completely wrong.
Plus, you can absolutely swap a 2.8 for a 4.3. Do a google search and you'll get tons of hits about it. Now whether you'll still be emissions legal, I can't answer for your state.
PsychoAndy
10,735
-PAB
nik
HOMEWRECKER! :|
-PAB
DougK62
8,035
This supposed ASE certified fella sounds like a moron. A carb doesn't have anything to do with the engine's dosplacement. Also, the 4.3 will most DEFINITELY fit in your truck. Heck - they made them with 4.3s straight from the factory. A 4.3 will bolt into your truck using all factory parts - you can even put a 350 V8 in there pretty easily. The 2.8 is a 60 degree block - meaning that the angle between the two banks of cylinders (the "V") is 60 degrees.
Go tell him he's a disgrace to his profession.
Any chance you just misunderstood what he was saying?
Viper GTS
38,107
433
Viper GTS
nik
Always question. :)
While I was willing to consider the possibility that I was wrong, I was pretty sure I was right.
Displacement = (pi)(bore/2)²(stroke)
Viper GTS
ElFenix
102,402
8,574
while theres no replacement for displacement, being blown is pretty nice
Jzero
18,834
nik
Not that you heard him wrong, but more that he meant to say it would give power similar to the 4.3, but it came out saying to would make the displacement the same....?
I dunno hehehe
It doesn't make sense to me either :)
NikPreviousAcct
52,763
nik
I dunno hehehe
Hhe and his girl were having some issues and he wasn't in the best frame of mind, come to think of it.
nik
NikPreviousAcct
52,763
Originally posted by: Pacfanweb
Nik,
The 4.3 won't fit in my rig. I've heard this from him and several others - one of which makes a living doing this kind of work. :)
nik
BoberFett
9
Viper GTS
nik
Always question. :)
Viper GTS
You mean
Displacement = (pi)(bore/2)²(stroke)(cylinders)
MrPhelps
1,421
The cars computer will be a large chore to make it work with a different motor or carbs. Nothing is impossible.
I don't know anyone that ever had a blower but I used Nitrious oxide alot.
