I had a 94 Accord EX with an automatic that went out. It never slipped. It just started shifting harder, to the point it was almost snapping my head back. Started sort of minor but got very bad shortly afterwards. Maybe I am confused, but I think someone on this forum said that 98 Accords with V6 engines had bad trannies and that Honda was in some cases extending the warranty or somesuch. When my trannie went, I found out that for that model, at least, you have to check the trans fluid with the car NOT running, unlike most American cars of that age (as I remember). Also, you had to use Honda fluid. I told the shop thqt replaced mine that I had heard that Honda automatics required Honda fluid at just about the time they were to put fluid in. They then checked with Honda and found they did have to use Honda fluid. I think I basically burned mine up from checking it wrong. Do a search and see if you can find the earlier post as I am quite sure it is here. Good luck
