murphy55d
yeah more problems with my Olds. 🙁
96 Bravada, it is having intermittent start problems. Sometimes it'll start right up, other times it won't fire up first try. My cousin who usually works on my car says he thinks it MAY be a "distributor module", and the part is around $120. Does this sound like it may be correct? He says he isn't 100% sure though. He hooked it up to the ODB thing and it isnt coming back with any codes. I am not sure what other information I should provide. He also said the times it won't fire right up, there either ISNT spark, or it's LOSING spark. (not sure if theres a difference), and it sounds electrical. is that what the distributor module controls? is that even a real part? (i think thats what he said it was called)
should I take it to another garage and have them look at it? any thoughts?
edit: tried to start it this morning,turn the key, engine cranked, but would not start up. Just sat there. Eventually then the brake became impossible to press in and I could not even get it into Neutral for it to be towed. Eventually got it into neutral by putting on E-brake. Any further thoughts?
