iamaelephant
You didn't "break" your cat. There's nothing to break in there FFS, it's just a pipe with a couple of catalysts to convert harmful gases into slightly less harmful ones.
I can't see your o2 sensor in that picture, but if it's not dangling down then it's ok. The check engine light could be a number of things, easiest way to diagnose will be to take it to a mechanic that has a computer to plug into it. You've probably knocked a plug loose somewhere.
