YACT, I think my car broke, help me fix it.
notfred
38,241
4
My car doesn't run right anymore. I think that maybe it's the transmission, either that or the radiator. Please help!
Mr N8
8,793
Lick the transmission. If your tongue gets seared, and you taste something akin to rabbit fur and coal tar, you need new seals.
MMY, please. :D
notfred
38,241
4
Originally posted by: Electric Amish
Shoot it and put it out of it's misery!!
Which part is "it"? Sorry, I'm car illiterate, where should I shoot exactly?
Iron Woode
31,361
12,849
You need to adjust your muffler bearings.
conjur
58,686
Needs new ball bearings. And perhaps a new gasket.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Originally posted by: Roger
It doesn't run, that tells you right there that it's a Ford.
Bold statement from the driver of a lime green VW Bus :p
lol @ both of you doufus's
AgaBoogaBoo
26,108
I know what you're talking about! Car makers are getting cheap these days... I mean, come on, who wants to turn the key? Oh yeah, try sticking the key into a hole with a weird shape.... near the stearing wheeeellleee thingy and see if it fits. If it does, t urn the key until you hear a sound. Then, let go and kiss it five times and pray to your god too.
DainBramaged
23,454
41
Originally posted by: wetobasura
better rotate the air in the tires. and add more blinker fluid while you're at it.
What was really bad was when I had a BMW, you could only rotate the air with the german air that was like 20 bucks a bottle. And my GAWD, the blinker fluid was OUTRAGEOUS. Even more than the camshaft portholes.
Squisher
21,204
66
Naw, you guys are all wet,
He needs to put fresh air in the tires, the air has gone stale.
Or, it could be the Kanuten valve is pump'n oil.
Cyberian
9,999
My friend's car had the exact same problem.
His distributer didn't distribute, his generator didn't generate, and his pistons didn't work either.
