Rumpltzer
Cliff's note:
I've been quoted $575 to repair this. Fair or not?
Detailed version:
2004 Accord coup (two door) with damage to the rear, passenger-side quarter panel shown here and here.
The dealership reccomended a shop. The guy looked at it and said they'd need to loosen or remove adjacent body parts (rear bumper, rear spoiler, tail light assembly, remove the rear window) to get the paint/clear coat into the seams. He said they'd repair the topographic damage, paint the damaged area, and then clear coat the entire panel.
The panel runs from the rear bumper, under the rear window, and then over the passenger-side door. It's shaped sort of like a garden watering can with a long spout.
The quote (in hour units):
Loosen rear bumper - 0.5 hours
Remove/install tail light assembly - 0.4 hours
Remove/install trunk lid spoiler - 0.7 hours
Remove/install rear window - 1.0 hours
Replacement glass kit - 0.3
Remove/install roof molding - 0.5 hours
Remove/install lower trim - 0.3
Repair quarter panel - 3.0 hours
Cover for overspray - 0.3 hours
Color tint/sand & rub - 1.0 hours
subtotal = $304
Paint & clearcoat work - 3.6 hours
subtotal = $137
Paint supplies - 3.6 hours
subtotal = $94
TOTAL = $575 (after tax and parts)
I like that they're doing the job right. I'm sure the hours are being overcharged, though. For instance, I installed the spoiler myself. It was the first time I'd ever done it, I had to measure and drill the holes in the drunk, install the spring system, and thread the wiring for the light. It took two hours. It's held on by six bolts, and I don't think it should take 0.7 hours to remove it. I don't even know why it need to be removed when it's not in the way at all if you just open the trunk.
Anyway, it comes down to $575 to make the repair. Fair or not?
Oh, and if anyone knows of a good body shop in Ventura County, CA, I wouldn't mind taking it in for another estimate.
Detailed version:
subtotal = $304
subtotal = $137
subtotal = $94
