YACT: Hill starts in a manual
Goosemaster
48,775
I try not to stall the car
EDIT:
seriously. this is what I do:
1) keep brake pedal pushed.
2) pull up the handbrake (wait until light changes)
3) rev the gas, let the clutch out as I apply the gas and release the handbrake.
When I don't have time to use the handbrake I jsut make sure to rev REALLY quick and use equally velocity in letting out the clutch and applying gas
Zim Hosein
Super Moderator | Elite Member
65,426
408
Originally posted by: PaulNEPats
Out of curiosity, what method do you guys use?
A foot on the brake pedal and one on the clutch, before I turn the ignition. Keep in mind the "hand brake" is locked" as well :)
EatSpam
6,423
I'm just really fast at switching from the brake to the gas and getting the car going.
According to one of my coworkers with more credit than sense, BMW's manual cars will sense the hill and gently apply the brakes until you get going.
Goosemaster
48,775
cool.
for most cars, what really matters is getting attune to the type of poer delivery you are dealign with. For example, my honda accord is a DOG on a steep hill@1000rpm. I have to be reving to at least 2.5k to 3.5k to ahve some power.
On a hill, I jsut make sure that when the clutch grabs, it is in the range, being careful not to spin the tires.
It not hard...jsut practice, practice, practive...
Zim Hosein
65,426
408
Correct me if I am wrong EatSpam, but PaulNEPats is asking about "starting" a car on a hill, not being on stopped on an incline.
skyking
22,798
5,967
depends on the rig and the hill, but I try to do it all with the brake/gas sidestep. I try to avoid the handbrake option, because on many rigs it is not an option.
Goosemaster
48,775
oh. I think he means being at a light but whatever
dude. I doubt that's the question. ALl you do is pop the clutch as you apply the break and turn the key
EatSpam
6,423
Oh.....I get it. I'm not sure if my car can even be started that way... PassLock and all.
Vic
50,422
14,337
Quick feet.
Plus... while your right foot is moving quickly from the brake to gas, let the clutch up just to the point where it will keep the car from rolling back, then be quick with the gas just before the engine stalls.
mugs
48,920
46
I start the same way I normally do... I just move my feet a bit faster.
Before you get the hang of it (you will), the hand brake helps.
clickynext
2,583
Usually I just rev a little higher than usual and move my feet quickly, but if it's the type of hill where it only takes a second or two to slide back into the car behind if I make a mistake, then I use the handbrake. Using the handbrake is really the easiest technique, but I'm lazy.
NutBucket
27,155
635
Originally posted by: Vic
Quick feet.
Whatever man, don't you have a hill-holder anyway?
Vic
50,422
14,337
Quick feet.
No, I think that's only in the Foresters.
Genx87
41,091
513
My A4 is very forgiving on the clutch. I just give it some gas and slowly pull the clutch out.
NutBucket
27,155
635
Quick feet.
Really? I could've sworn my gf read she has it in her WRX.
vegetation
4,270
Just get used to switching from brake to gas quickly. Unless we're talking about something greater than a 15% grade, this should be easily learned with almost zero rollback. At grades beyond 15%, then I would go for the handbrake method.
aplefka
12,014
I suck at hills. Then again I've only driven stick once. For some reason I had trouble getting it going at a light, but when in a parking lot, I had no problem at all. In a matter of an hour and a half, I stalled 3 times. Then, trying to park in our driveway (incline), stalled 3 times more. It's hard stuff when you've never done it. Hopefully I'll get the hang of it.
Snapster
3,916
Slowly let the clutch out till I feel it bite, then remove the handbrake and apply the 'gas'.
randomlinh
linh.wordpress.com
there's no pressure in a parking lot vs real traffic.
iamwiz82
30,772
13
I just let off the clutch and hit the gas, like any other star. If you are quick enough you'll roll very little
BobDaMenkey
3,057
I haven't had to deal with hills too much thankfully, but I just move a bit faster, and try to get going a bit quicker. If a roast the rears a little, all the better. I live in the Pheonix Metro area of Arizona though. We don't have hills. Just lots of big flat desert.
