[/L]Originally posted by: TechnoKid
Originally posted by: gotsmack
anyone know where I can buy break rotors online? Is it is for a 88 volvo, 760 Turbo RWD
http://www.importeccatalog.com/
It could just as well be something else besides the rotors, like suspension components, tie-rods, etc.
And no, unless your current rotors appear to be heavily ringed, scored or glazed, or your pads are worn down a lot, you do not need to get new pads.
Actually, the proper break-in procedure for new rotors is to use old pads on new rotors, and new pads on old rotors (assuming same friction material between pads). This is according to many automotive brake pages out there.
On a car that old, I'd probably get all new rotors and pads. But you should also get a complete brake fluid flush every two years; brake fluid absorbs moisture over time. And have the master cylinder checked out too, as well as all the calipers for proper piston operation. Also get all suspension components checked.
Proper brake pad bed in procedure (under "prevention) can be found here as well as myths about brake vibrations:
<a target=new class=ftalternatingbarlinklarge href="http://
[L=http://www.stoptech.com/whitepapers/warped_rotors_myth.htm">http://www.stoptech.com/whitepapers/warped_rotors_myth.htm</a>[/quote]]http://www.stoptech.com/whitepapers/warped_rotors_myth.htm[/L]
The pads still have plenty of meat left on them, I'll just get the break fluid flushed and have the rotors, master cylinder, and calipers checked out by a mechanic. What is a caliper?
Thanks
