The Batt?sai
- Jan 18, 2005
- 5,170
- 1
- 0
A typical ABS is composed of a central electronic unit, four speed sensors (one for each wheel), and two or more hydraulic valves on the brake circuit. The electronic unit constantly monitors the rotation speed of each wheel. When it senses that any number of wheels are rotating considerably slower than the others (a condition that will bring it to lock[1]) it moves the valves to decrease the pressure on the braking circuit, effectively reducing the braking force on that wheel. Wheel(s) then turn faster and when they turn too fast, the force is reapplied. This process is repeated continuously, and this causes the characteristic pulsing feel through the brake pedal.
from wiki
the noise is the calipers. you people are newbs
Exactly what it says "While the brake pedal is being applied"
it still senses the wheels slowing down. the noise your hearing is it pulsing the calipers.
do you know what ABS even stands for??
UNLESS you are SKIDDING ABS will NOT apply.
it is a DORMANT ANIMAL, when you STOP on ICE, and you LOCK a WHEEL UP, it then ENGAGES, it does NOT do ANYTHING during NORMAL driving.
sort of like you should NOT be saying ANYTHING in a thread you know JACK SH;T about.
now get the FVCK out of this thread. you fvcking dumbass
quoted for future generations to marvel at his ignorance and vulgarity.
Get out of this thread already. You have no idea of what you're talking about.
About ABS
from your website retard
How can I familiarize myself with ABS?
Read your owner's manual for more details on the complete operation and benefits of ABS. The antilock brake system is speed sensitive, and will not activate at very slow speeds. One way to familiarize yourself with the operation of ABS is to test drive the vehicle at a speed above which the ABS activates (usually above 10 mph) in an unobstructed parking lot and apply the brakes firmly. It is easier to activate the ABS on a wet and slippery road surface. The antilock system should prevent the wheels from skidding. Pulsation may be felt in the brake pedal and you may hear a clicking sound. Avoid pumping the brake, even if the pedal is pulsating.
