Originally posted by: nakedfrog
Turn the key on and off about five times.
Just to the position before it actually starts, of course... so Off-On-Off-On-Off-On, that should do it. Works on my 04 Chrysler.
That'll spit out a code on the odometer.
Oops, yeah, then you can check it on TroubleCodes.net">http://www.troublecodes.net/</a>
Originally posted by: Pepsei
yeah, all i need is the code, i could wait until tomorrow and using my buddy's tool to get the code. i just want to know what the heck is wrong with my brand new 1 year old truck. i already check the gas cap and it is screw in tight... so...
Originally posted by: Feldenak
That On-Off trick work with Saturns?
Originally posted by: YJK76
i just paid $500 to get the knock and O2 sensors fixed because my engine light came on. there's a key trick you can use to turn the light off? if so, specific to dodge 2004?
i have a 97 maxima btw...
Argh, I heard this is a common problem with Dodge trucks. I guess I'll have to reset the light and then maybe looking into buying a new cap.
