Exactly. It's not like it's more difficult to do...Originally posted by: mrchan
Originally posted by: Zenmervolt
Do you have any idea of just how concentrated the hydrogen would have to be in order to ignite? You'd need to be pulling a high-amp fast charge in an area with zero airflow for a long time in order to generate enough Hydrogen to cause an explosion. A car's engine compartment is not confined enough to allow that kind of build-up unless you're trying to jump the car indoors, and even then if you have half-decent airflow in your shop, it's not an issue.Originally posted by: BoomerD
ok...hyper-paranoid...try smart....Originally posted by: Zenmervolt
No, it's just because hyper-paranoid people are afraid that it the negative clamp will arc when you take it off and ignite the hydrogen gas that a battery emits when it's charging. It's overkill and I've never once worried about it.Originally posted by: fbrdphreak
Something about wearing your battery faster, not good for it. You have a 93 Sable, there should be plenty of metal ground contacts in that engine bay; just use those. People with newer cars sometime have to contend with an all plastic engine bay and might be forced to hook it to the neg post on the battery; not the best idea, but it shouldn't blow anything up.Originally posted by: archcommus
Why is this?Originally posted by: AStar617
If a battery is flat dead, you'll hear nothing.
If a battery is very low but not flat dead (i.e., if you have jumpers connected to a flat dead battery but didn't wait long enough), you might hear clicking, or slooooow to normal cycles of the starter motor.
Either let a running vehicle sit on the dead one with cables connected for ~15 or more mins (remember to have negative to ground on the dead vehicle, not the neg battery post), slow charge the dead battery with a battery charger, or replace the battery outright.
ZV
http://www.aa1car.com/library/battery_safety.htm
http://www.expertwitness-electric.com/i...orders/Battery_Explosion_(SSB)_054.jpg
http://www.uuhome.de/william.darden/carfaq14.htm#explode
http://images.google.com/imgres?imgurl=...Doff%26rls%3DGGLG,GGLG:2006-11,GGLG:en
I repeat: It is for over-cautious people and you needn't worry if you're outside or in a properly ventillated area.
ZV
I've always done + to + and - to -, and you're probably absolutely right.
But I will be doing it the "right" way now. I mean... why not?
