- Aug 21, 2002
- 18,368
- 11
- 81
Originally posted by: Evadman
if you are in a cold cimate, ALWAYS run though the aux first, then the regular one.
And WHY would one do this?
Not only is this BS it defeats the purpose of the cooler in the first place Einstein.Originally posted by: Evadman
So you figure that ATF should always be as cool as possible? If it comes out of the trans at 280F, then cooled by the aux cooler, you think that the radiator will reheat it to 280F?
The Trans cooler usually goes in frot of the radiator when installed so it gets the coldest air. So, if it is -20 outside, your trans can be at operating tempeature, but the oil coming back from the cooler would end up being about 60 degrees instead of normal operating temp of about 200. Does this sound like it is conductive to normal operating dynamics?
What is my incentive to lie? I really dont care what you do, install one anyway you choose. By your reasoning you will have it installed the wrong way but why should I care what a dumbass does? I'm not at work you idiot, I went down to my garage in my house where I have all my tools and literature where I restore classic vehicles and have been doing so for 25 years. I don't have to work at an auto repair facility to know what I am talking about plus I even looked up the info to verify it since I don't want to mislead people.....once again, what is my incentive to lie? I really don't care what a bunch of pimply faced ricers do I was merely trying to provide the correct info instead of a lot of conjecture and guessing.Originally posted by: Evadman
Right I have no idea what the hell I am talking about. I bow to the extensive instructions you have in your garage. Which you are posting from at 12:30 in the morning. I always go to work to post on AT at 12:30 in the morning.
Your point? I have been working on cars this long and work on the new stuff too so I am up to date on my knowledge. I convert older cars to EFI on a regular basis so I don't think I am in the dark on new technology. You can beleive what you want, but by your reasoning in this thread you will have it installed improperly but I really don't care if you damage your car or not.....mine are plumbed correctly and that is all that is important to me.Originally posted by: Evadman
The first thing you do is come into this thread, and bash me. You have no clue what I do, how long I have been working on cars and trucks, or how much/recent my schooling is. Quite a bit changes technology-wize in 25 years, so I would not be so quick to bash someone. Transmission fluid, engine tech, and trans tech is quite a bit different now.
I did think about it, and the argument to plumb it the other way holds no merit in my opinion. If you are going to plumb it that way then just don't use one because it will do little good at any. I went through this whole process when I was young ang thought it was plumbed the opposite of the way it truly should be but I learned and all written reliable material I can find supports it being after the stock cooler in the radiator....I am not guessing or trying to reason out the answer....I looked it up, everyone does remember books right?Originally posted by: JC
It might not be the way you think it should be....but I don't see it damaging anything. And if you actually think about it, there's an argument to plumb it the other way.
Originally posted by: Jeff7181
Originally posted by: AmericasTeam
In my old car I use only a B&M Supercooler. Their largest. I run synthetic mobil 5w-30 oil in the transmission. I live in Cali, so cold weather isn't a problem.
In your situation I would run the cooler after the stock (in radiator) cooler. Don't worry about the oil getting too cold in the winter. It won't happen.
You run engine oil in an automatic transmission? I don't think so![]()
Actually you are guessing and it does make a difference, luckily you have it installed correctly.Originally posted by: SuperTool
I put mine after the stock cooler. I am guessing it doesn't make much difference.
The pour point isn't what I'm concerned about. What I'm concerned about is proper operation of the transmission. As I said, too cold isn't much better than too hot.
That B&M one sounds like a good idea... but as I said, I've already purchased a cooler, I was just surprised how the instructions say to install it, so I wanted people's opinion.
I can't believe that Roger hasn't lent his knowledge to this thread yet....
If you live in a climate with large temperature fluctuations, an oil thermostat must be installed, this will reroute the transmission fluid back to the transmission when the temperature drops below a predetermined value thus preventing over cooling.[/Q
this is crucial...otherwise in the winter you will never be able to shift into od!
switch to synthetic to like others have suggested.
pumping transmission fluid through the aftermarket cooler first and then through the radiator (stock) cooler will be wholly ineffective, you will end up reheating the fluid via hot engine coolant.
Give it up...you are wrong. Every set of instructions I have dug up including an automatic tranny book...plus the exalted ROGER...say it goes AFTER the stock cooler. I understand and appreciate your reasoning but it is simply not correct.Originally posted by: JC
But it could only reheat the fluid to engine coolant temp, which is proper operating temp for ATF.
