I was looking at Quaker state site and come to this
http://www.quakerstate.com/pages/carcare/whattoknow.asp#atf
Quota:
Myth #12
Adding a quart of ATF the day before an oil change will clean your engine. ATF added to the motor oil will clean the engine due to the high levels of detergent in ATF.
Fact
ATF does not contain detergent chemistry. ATF does contain dispersants, which have properties similar to detergents. But ATF is not formulated to withstand the combustion environment inside the engine. Quaker State® recommends that you keep the fluids where they belong: motor oil in the crankcase, and automatic transmission fluid in the transmission.
Do ppl do that?
Quota:
Myth #12
Fact
Do ppl do that?
