Originally posted by: SkoorbWe're anti-vw for reason. The newer golfs/jettas,etc. have known and documented serious reliability problems. There is a reason why VW is worse than mitsubishi for quality. Worse than Ford. Worse than Dodge. That smell could, as mentioned above, require removal of all upholstery from the vehicle. There may be rust in areas you can't dream of. There may be mold in areas you can't dream of. Flood damage cars, aside from having horrific resale, will sometimes illicit problems that all but cannot be solved. Maybe your tailights will go out and continue to go out, time and time again. VWs have bad enough problems as they are, that they don't ned this thrown on 🙂
You may do well. It may be an easy job to clean the smell out and mild electrical problems. But, I doubt it. If it was a quick fix the seller would do it and sell it for more than $9k.
