Originally posted by: radioouman
24008. It is unlawful to operate any passenger vehicle, or commercial vehicle under 6,000 pounds, which has been modified from the original design so that any portion of the vehicle, other than the wheels, has less clearance from the surface of a level roadway than the clearance between the roadway and the lowermost portion of any rim of any wheel in contact with the roadway.
Amended Ch. 462, Stats. 1984. Effective January 1, 1985.
http://www.dmv.ca.gov/pubs/vctop/d12/vc24008.htm
Sorry if I'm not understanding this correctly, but that sounds like you can't have your car lower than the sidewall of your tire.
Originally posted by: Demon-Xanth
Yup. Basically what it's saying that if the car's tires were removed, it should sit on the rim, not the frame. That's so if there's a blowout you still have some semblance of control and aren't a steel sled.
OOo. Didn't think about it that far. I figured you wouldn't be able to go over ANYTHING at that point without smashing your bumper.
Originally posted by: MasonLuke
ok, i'll say it:
FVCK THE POLICE!
Originally posted by: tagej
Cop simply properly enforced a law. Why the heck did the guy have to lower it anyway?
