Originally posted by: Gamingphreek
There is nothing you can do to prevent condensation besides buying exotic or water cooling.
You are not limited by heat at all. If your temps were around 70C for CPU Load and Case was like 40C then i would say you need new cooling and buy doing that you will achieve higher overclocks.
Something seems wrong. My case with 4 Panaflo Low Speeds running at 1/3 speed idles at 20C (22Load with all fans remaining at 1/3) and my ambient temp in my house is 69F. 6 Fans are not needed. How are they configured? You might be able to rip one out and get better temps.
-Kevin
i dont care about my CPU, thats maxed out period w/o going to extreme voltages and my temps are fine there. i'm not too concerned with noise either, because my WD Hd is by far the loudest thing in my system (high pitched squeel) and i'm not going to replace that for a while. plus i wear headphones.
my fans are setup at follows:
2 intake (controlled by Fan Only Connectors on PSU)
1 side panel intake with its own thermal probe stuck in GPU heatsink
2 PSU fans
2 exaust fans with thermal diodes under CPU bracket
my 6800GT on the other hand, i am pretty sure is temp limited. i have seen quite a few people with stock cooling not able to get over ~405/1080 (what i am at right now), but when they get an NV5 they can do 430/1150 and with a voltmod can do 450/1200.
those are just examples, but you get the idea.
If there is nothing i can do about condensation, scratch that idea...i'm not going to risk getting water all over my PSU insides/mobo/hds/videocard etc. ill just get an NV5 and see what magic it can work (hopefully).
