XP SP3
I'd like to know how activation works in SP3 as well.
That's interesting in Vista SP1 how they are removing "reduced functionality" - does that mean that the OS will simply no longer boot, instead?
A quick google search led me to this:
http://www.microsoft.com/press...07/dec07/12-03wga.mspx
The key points:
PressPass: What are the latest piracy threats that you see today to Windows Vista, and what are you doing about it?
Sievert: We know that Windows Vista is a lot harder to counterfeit than Windows XP, but we also know that pirates will keep trying. We currently see two primary types of exploits pirates often use to generate counterfeit versions of Windows Vista. One is known as the OEM Bios exploit, which involves modifying system files and the BIOS of the motherboard to mimic a type of product activation performed on copies of Windows that are pre-installed by OEMs in the factory. Another is called the Grace Timer exploit. This exploit attempts to reset the ?grace time? limit between installation and activation to something like the year 2099 in some cases. Implementing exploits involves extreme alterations to key system components and can seriously affect system stability.
So we are taking action. SP1 will include updates that will target those exploits and disable them.
PressPass: What will happen to systems which have those exploits?
Sievert: Although our overall strategy remains the same, with SP1 we?re adjusting the customer experience that differentiates genuine from non-genuine systems in Windows Vista and later in Windows Server. Users whose systems are identified as counterfeit will be presented with clear and recurring notices about the status of their system and how to get genuine. They won?t lose access to functionality or features, but it will be very clear to them that their copy of Window Vista is not genuine and they need to take action.
This is a change in tactics from our current approach for Windows Vista, and it is based on great feedback from customers and partners. With the original release-to-manufacturers version of Windows Vista we released in November 2006, counterfeit systems can go into a state called reduced functionality mode, which essentially suspends a number of features of the system until the user takes action to get genuine.
Our new tactic, which takes effect with SP1 for Windows Vista and also will be part of Windows Server 2008, due out next year, is a proven and effective way to combat piracy. Customers want to know the status of their systems, and how to take action if it turns out they were victimized.
It?s worth re-emphasizing that our fundamental strategy has not changed. All copies of Windows Vista still require activation and the system will continue to validate from time to time to verify that systems are activated properly. What is changing with SP1 is the nature of the experience for those systems that are never activated or that fail validation.
Originally posted by: MichaelD
RE: New Windows Activation Module
How will this effect Corporate copies that previously didn't require activation? I run a legal corporate copy of XP provided by my work. Never had to activate before.
I've slipstreamed the RVMUpdate package (all the updates from SP2 release to Nov 07) into my existing copy, but SP3 would be a nice addition for sure.
Anyone running a Corp copy and apply SP3 yet?
I put SP3 on a test rig at work running VLK XP and it seemed fine. No activation issues.
TBH, it'd be a sure way of making every corporation worldwide avoid SP3 if it suddenly made all their workstations suddenly need activating.
AFAIK, the system works but you get nagged about the OS being illegal.
Reduced funtionality wasn't exactly hard to get around anyway if you needed to temporarily get in and work on the system.
