XP Pro Vs. XP Home
blackcatak
198
I just built a computer for a friend and he bought XP Pro. Recentley his co-Workers in the IT Dept told him that Home was much better for gaming because Pro had extra DLLs running. Is their any truth to this & is Pro inferior to Home? And would Home be a better Gaming OS then Pro? Just wanted everyone else's opinion.
Algere
2,157
XP Pro has better security and supports Intel HT Technology. The Pro version probably does have extra resources running in the background in comparison to Home so there is truth in that but I think the extra resources running in the background are pretty negligible
SpaceWalker
791
I like running HOME on my laptop, and run PRO on all my desktops.
By the Way Algere, HOME supports HT also.
On paper, yeah, PRO does run extra services that are not needed on HOME, but i have tested games on both setups and never really noticed any difference either way...
Nothinman
30,672
There probably is a bit of a difference since Pro supports a few things that Home doesn't, but if it makes a performance difference you're doing something really wrong.
that and networking w/ home is a pain.... isn't still sitting on winn98?
XP Home is the same NT system as XP Pro, just with a bunch of stuff limited and/or disabled.
Sunner
Home supports HT as well, just not SMP.
Algere
2,157
news to me
Did Home always support HT or was it through some update? cause when HT came out I remember hearing that Pro was the only WinXP version that supported it.
pitupepito2000
1,181
As specified by someon else XP Pro does ue more resources, but they are negible and the advantages that you can get from them are worth it. They are basically the same, XP Pro is Windows NT version that should have come after Win 2k, but they changed the NT name for marketing purposes. Windows XP Home is a XP Pro cut down version. Here is a couple of links to read
Text[L=http://www.microsoft.com/windowsxp/whichxp.asp[/url]]http://www.microsoft.com/windowsxp/whichxp.asp]http://www.microsoft.com/windowsxp/whichxp.asp[/L][/L]
[url="http://www.microsoft.com/windowsxp/pro/evaluation/features.asp"]more detail on featues of XP pro
I hope this helps,
pitupepito
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
Windows XP Home has always supported HT.
AndyHui
17
MS Word and MS Works have always been separate products.
pitupepito2000
1,181
Originally posted by: somekid617
Does pro have word, works, and all that still? or do i have to buy it?
just like AndyHui said Windows comes only with notepad and Wordpad. You would need to get other software to complement it. I would suggest you to download and install open office and also gimp. The only thing that windows is good for after a fresh install the only thing windows is good for is SOLITARY ;).
Openoffice is an extremely good alternative to Microsoft Office, and in my opinion better than M$ office and my favorite option is to export documents to pdf. Openoffice also stores files using its own xml format which is very good and compresses the size of the file. Gimp is a very good image manipulation program, for most users including myself does all what you need, no need to have photoshop with gimp.
I hope this helps,
pitupepito
Sunner
news to me
There was some confusion bnack then since it doesn't support SMP, so some people assumed that it wouldn't support SMT(or HT in Intel-talk) either.
blackcatak
198
I am going to have my friend just read the post here so he can make up his own mind. Thanx for all who replied.
jswjimmy
892
ive run xp home and pro. on a clean install i see just a 16 point drop in pcmark2002 with pro. i think that much does not matter so i run pro.
