xp desktop problem help
fastvideo
932
fresh install winxp, all i have on the desktop is the recyclebin icron only, is this normal?
bspate
43
If you want to make it look like the old way, then go to your display settings, and then go to the desktop tab, and click customize desktop, and check the boxes for the icons you want.
