Originally posted by: Infrnl
I am using an Vendetta 2 basically same cooler; cooling My 9550 @ 4+ghz and realtemp says 18-19c normal use, sometimes a degree or 2 higher. max temps around 30c. CPU is at 1.2v though.
Core temp reads about 4-5c higher; however I do not feel much if any heat if I touch the base of the cooler, so either way is running very very cool.
Will easily cool yours; nothing to worry about. I am also currently using push pins, will be changing out to screw/spring mount today
Impossible...unless your ambient air is 15c or so. It is impossible for an air cooler to get lower then ambient...it's in the physics.
