fffblackmage
- Dec 28, 2007
- 2,548
- 0
- 76
I use ATI Tray Tools to monitor things.they don't fluctuate, I've had gpu-z enabled on my second monitor and watched it, it's always at 850mhz. Load changes, clocks don't, I'm at a loss as to why it sucks.
Are you using the defective 4890 now? Can you use the monitor "GPU Activity %" while running a benchmark or game? You'll have to use ATT. I don't think you can see the fluctuations on GPU activity with the way GPU-Z displays the graphs.
In case you've never used ATT before...
When you have it running, you right click the icon in the system tray, hover over "Hardware" and select "Monitoring Graphs."
Click "Add" and under "Sources" tab, you can select the things you want to monitor. You can select multiple sources to show in one graph. Click "OK." You can add more things in separate graph by clicking "Add" again.
Should look like this. The green line on the bottom graphs shows the proper load while I was running the SF4 benchmark, but I think I remember seeing it fluctuate a lot when I was still testing the other 4890.
