Have you tried downloading the drivers for your monitor(not the video card)? Sometimes that helps .
I did use the monitor's drivers. I did the update driver deal on the monitor.
Try disconnecting and reconnecting the monitor while the computer is on sometimes it will redetect the display properly. Also you could try deleting the cached EDID Windows keeps in the registry and/or use Powerstrip to take a look at what it's got currently for the monitor and generate your own settings for it if you can't find a .inf for you monitor on the net.
It's funny you wrote this because this is exactly what I did. I plugged in the cable directly into the monitor and 1920x1200@60hz! I swapped the cable backto the KVM and 1920x1200@60hz. I turned off the computer and started it again and back to 1600x1200 again! I tried powerstrip earlier and it made no difference after making a custom driver. Most likely I did something wrong.
dual-link DVI cables on both sides of the KVM?
The KVM is a DVI-I I belive. It has the long slot with 2 pin holes on the top and bottom. I am using the VGA cable going from the monitor to the KVM because for some reason when I use a DVI-D cable going from the KVM to the monitor, it does not display anything. The only working source is the VGA. In addition, the monitor can only accept DVI-D cable.
Maybe this Avocent switchview 4 ports KVM is funky. There hasn't been a firmware update since 2007. I may just buy a new IOgear DVI KVM switch and that may solve the problem. It's really annoying though that this doesn't work but the much older NVIDIA cards have all worked fine.
