Xeon X3210 or the E8400
aigomorla
21,095
3,605
Originally posted by: alfa147x
Im not a big fan of AMD i rather have an Intel ...
But performance will overcome fanboyism
any intel chip that can do this?
i think you missed my post with the 227 dollar quadcore that shouldnt break your budget.
alfa147x
29,307
lol not this time, thanks ill look into it
http://www.ewiz.com/detail.php...d9ad6cdb50b9b57639e771
here 227 dollar Kentsfield good to go on LGA775 boards. Xeon X3210 uses an 8x multi instead of 9x multi.
Thats if you need a quadcore, and are heavy into encoding or multi threaded aps. And yes this will pwn a phenom expecially overclocked.
8x400 ~ 3.2ghz with decient cooling is most definitely possible on this chip.
Sep 16, 2007
42
Originally posted by: harpoon84
Originally posted by: Iketh
Originally posted by: Markfw900
And 2.57 vs over 4 ghz ? It can almost equal the quad even if you had smp software that uses 4 threads. And I think the 8400 is faster per clock, so maybe they are equal.
something tells me OP wont be overclocking... and if he/she does, would you rather have a much more stressed dual running all the time or a slightly o/c quad??
LOL I like how you try to spin your Phenom sucking at overclocking as a positive! ;)
An E8400 @ 4GHz wouldn't be any more 'stressed' than your Phenom. Both chips would be running close to the limits. It just happens that the limit for the E8400 is around 4GHz, whilst your Phenom is around 2.6GHz. Just because the overclock is huge doesn't make it 'stressful'. It's called headroom, and the E8400 has heaps, whilst your Phenom has little. :p
excuse me, i can boot this phenom at 2.8ghz 1.5v and run benches... THAT would be stressing it... u dont think at 2.6 1.3v it'll last 10 years??
harpoon84
1,084
Yeah, and you can boot an E8400 @ 4.3GHz 1.5V and run benches, THAT would be stressing it too... you get my drift?
The E8400 has heaps of headroom to spare, your 9500 doesn't. It's that simple.
v8envy
2,720
aigomorla, any ideas re: which budget boards will support that Xeon? That's a fantastic deal, the xeon stock coolers aren't complete crap for a budget overclock.
I'll go look re: my ds3l right this second, if it's good to go I may just have me *another* quad. Gah. This hobby can get stupid.
lopri
13,316
690
I'd be trying out Phenom like yesterday, IF THE FREAKING PLATFORM WAS STABLE. All I'm hearing are mysterious lock-ups, OS install failures, sudden performance drops, hard disk or raid array disappearings, etc - which all point to the platform immaturity. To make matters worse, they're not even cheap. Shame on AMD..
v8envy
2,720
Lopri, that's got me worried as well. Where there's smoke there's fire. Plenty of reviewers downplay 'minor issues' they encounter even in the brief time they do reviews, but the issues certainly don't sound minor to me. I had lots of fun with Slot A and a VIA chipset board when those were brand new, I'm not into the whole alpha testing a platform thing these days.
Others users report 0 problems.
So it boils down to: "Do you feel lucky, punk? Well, do you?" Stories of the 'cheapie' (read: same price category as a DS3L or P35-E or Neo2 or blood iron) AM2+ boards physically catching on fire aren't exactly encouraging. My answer to that is: heeey I think I'll try that cheapie Xeon instead...
aigomorla
21,095
3,605
GIGABYTE P35-DS3L :D
virtually any p35 board will work for that processor. Its the same exact chip as the Q6600 only with a 8x multi instead of 9x
goobee
2,005
10
goobee.org
I am returning my Phenom 9500 to newegg. I was hoping to get a bit more performance over my old processor, an e6600 overclocked to 3ghz. I did not see any performance increase even with software that was SMP aware. Additionally, stability with the Phenom was somewhat shaky. Perhaps it's because the platform is new but for me, it's not a viable option.
imported_dinGLeBeRRy
15
its time for work.
Markfw
May 16, 2002
27,344
16,175
My X3210 was on a Gigabyte S3 board (P965) and now its on a DS4 (P35), both no problems.
alfa147x
29,307
By DS4 do you mean the GIGABYTE GA-P35-DS3L LGA 775 Intel P35 ? because that is the board I was looking at
Markfw
May 16, 2002
27,344
16,175
There are many Gigabyte boards, most start with "GIGABYTE GA-P35-" and end with DS3L,DS3P,DS3R,DS4,DQ6 etc.. They should all work. I have a DS4 which currently has an X3210 in it, but the DS3L is also a fine board.
aigomorla
21,095
3,605
ANY LGA775 Board will take this cpu.
If you want to overclock it deciently, get a decient quality board.
Gigabyte P35-DS4 is an excellent board. So is the ASUS P5K-E however if your going to load it up for long periods of time, like encoding, F@H or WCG, you need to put some enzo ram sinks over the top mosfets to keep those cool as well.
alfa147x
29,307
ok, this is the 1st time i will be overclocking a system and dont want to push it too hard
I know what mosfets are on robots but never cooled ones on a computer do the one near the CPU need the heat sinks or all of them?
Any good tutorial for OCing ?
