purbeast0
- Sep 13, 2001
- 53,745
- 6,620
- 126
Originally posted by: AnnihilatorX
Originally posted by: Injury
Originally posted by: KingPhil
True........ but, oh what's that word? oh ya, SOFTWARE.......... can't someone write a piece of software to compensate the differences????
no... no they can't.
It's 90% in the lasers of the systems and the way they read the discs.
computers can't even READ the discs, HTF are they supposed to translate the data?
Smooth thinking, jackass. If it were a possibility, do you think it would take 5 years after the systems came out for someone to figure out this master plan of your's?
No actually PS2 and Xbox medium are DVD discs which is 100% compatible with PC
You can even backup your games with PC using DVD burner if your console is modded to read burnt DVD media
no you are wrong. you cannot put an xbox original in a PC and make an image of it or even do a direct copy. the ONLY way to get an xbox iso is to put it in your xbox, rip it to the xbox HD and then xfer it to your pc, then either image it and burn it, or burn it as a data disc.
also, the .xbe file is not the entire iso as many people in this thread have said. the .xbe file is just the xbox equivalent to a windows .exe file ... its just the executable (Xbox Executable).
