Your XBOX Requires Service. Please Call Xbox Customer support..
someone help?
Originally posted by: hevnsnt
Is it modded?
Is it modded?
yes, it is..
Okay, what mod chip, what bios did you install, have you upgraded the HDD and if so with what?Originally posted by: SofaKing
i'd rather not call MS support.. i have a modded xbox and i'd rather not take the risk. and it shows no error code..just the "you need service" message
Oh dear. Well, you may want to learn quickly.Originally posted by: SofaKing
i have no idea what bios he installed but there's a matrix modchip in there. this is my friend's xbox and i purchased it for him from someone on ATOT.. i have to get it to work before my friend picks it up. i think the modchip may have been misaligned, since it's solderless.. all that banging from the fedex truck must have done something. problem is i'm pretty much a noob and i don't know how to open up the xbox, or even how to identify the modchip..
I suggest you buy the bits for a... erm... whatever you call the screwdrivers that take different hex-shaped bits. Probably cheaper, just as effective.Originally posted by: SofaKing
crap i don't have those screwdrivers.. i guess i'll go buy a set at lowes
Originally posted by: shuan24
just a question, when is unlocking and locking the hdd necessary?
If your chip has a switch you should be okay. Just make sure to turn the chip off before you connect, and that you've done a "Stealth" install.Originally posted by: MercenaryForHire
When you want to tempt fate and try to play on Live with a modded box.
- M4H
